Is The Hudson Broadcast 24v a 'sizzler'?
equalsqlequalsql Frets: 6140
edited August 2019 in FX
A question for owners of this beast:
Is the low-gain on the Hudson Broadcast 24v pedal transparent? i.e. Can it add just a sizzle to a clean tone without robbing bass mids or treble? I've heard demos with it cranked and gnarly but am interested in it's more subtle processing.
  • danishbacondanishbacon Frets: 2695
    edited August 2019
    Yes it can. I prefer it to the std version
  • benmurray85benmurray85 Frets: 1396
    I have the Peach Rosso Corsa version - not sure if that’s 24/18v but it definitely does really light gain very well. That’s how I use it tbh, hardly adding any drive just a bit of colour.
    How very rock and roll
  • equalsqlequalsql Frets: 6140
    Sounds good, I'm really looking for the minimum amount of tonal change, just the added sizzle.
    I use two Hudson Sidecars for just a bit o drive and crunch, then a clean boost for volume jump, on either, great IMHO.......
  • smudge_ladsmudge_lad Frets: 668
    I had a 24v version and found that the pedal removed a lot of the low end/thump, even with the knob turned up to full (counter clockwise)
  • NorthernStompsNorthernStomps Frets: 398
    The broadcast can do low gain stuff very well but if it’s complete “transparency”
    youre after I’d say the Sidecar was probably a safer option.
    The broadcast does add something to your sound, which sounds great to me
    Facebook: @northernstomps // Instagram: @northernstomps // Twitter: @northernstomps
    Specialist Retailer Of Handmade British Stompboxes // https://www.northernstomps.com/
    Currently Stocking: Hudson Electronic/Raygun FX/Zander Circuitry/ThorpyFX/Rainger FX/Life is Unfair/ Magnetic Effects/Fredric Effects
  • bbill335bbill335 Frets: 1380
    That's weird. Was the gain really low? There's a lot of low end added when you wind the gain up.
    I definitely noticed it more with the low gain side. Can't remember now how much it affected the high gain side. This was ultimately why I parted with the pedal
  • pmgpmg Frets: 298
    I wouldn’t describe a broadcast as a transparent pedal, it definitely colours the sound, albeit in a nice way.  There’s other pedals out there which will suit your transparent needs
    edited August 2019
