Looking for dual concentric 250/500k vol pot
JMP220478JMP220478 Frets: 421
Looking for Fender part no 099-0847-000 or CTS or equivalent for HSS setup on an MM Silhouette ie just vol n tone .
Current JB HB bridge pu  really hasnt worked out despite being allegedly 250k pot friendly ..
only stockists seem to be US ..
  • ICBMICBM Frets: 72367
    Use a 500K pot and a 470K resistor to simulate a 250K when it's on the single coil settings.
    @icbm - is there a website with a diagram n how does this work with split coil position 2 ?
    @Winny_Pooh - whats the part no - as I think that might be the “jazz” bass pot ?
  • Winny_PoohWinny_Pooh Frets: 7771
    Says PN 019268049
    Is the coil split done with the pickup selector switch? That makes things a bit more tricky - but then you can't use it to select volume pot values either.
    Split coil on pu selector - trying to mimic myshawbucker std strat setup on a silo
    In that case you can't use a dual-gang pot either, since there will be no means of switching them. You're going to need a Superswitch.
    http://www.fmicassets.com/Damroot/Original/10001/Fender%20Am%20Std%20Stratocaster%20HSS%20Shawbucker%20011311XXXX%20Service%20Manual.pdf
    looks like postion 2 isn’t split after all on the shawbucker wiring  - though JB is clearly a pu with more output than std shawbucker pu
    No, but it does use a Superswitch.
    If you don't want to split the pickup then it's easy to do with a standard 5-way and the resistor.
    Or you could try changing the tone control to 500K first and see if that's enough.
