I've worked in maintenance hangars for 747, 777, A330 and there are some phenomenal hydraulics used for jacking them up. Some mishap then.
http://www.neillwatson.com/historic-motorsport/accidental-fighter-pilot/
*Every* jacking accident I've known has been the result of errors in managing/instructing the jack operators resulting in one jack going up either too much or too little compared to the rest. The result being a big bang and brown trousers all round.
C130J has big problems at the moment with the centre wing spar cracking. Wing off a possibility.
I was reading that Buccaneer pilots would select gear up when rolling and the WOW would retract the gear whilst the aircraft seeming appeared to still be on the ground. A very impressive sight, although I understand that one pilot at Honington had a bit of an embarrassing moment, as there's a pronounced hump on the runway.
I said maybe.....
Oops !
Engineers ran an engine test with the hydraulics off and no chocks... Brand new A340-600 written off... roughly $275M
...at £20 a week each from their wages.... that's er...
Similar scenario.....
Yep, JengO A-Line, then came back in AES and Eng Ops
I tipped a Honda Vision moped upside down off a workbench once, trying to undo the front wheel axle nut - it was pretty bashed up anyway and still worked so we didn't mention it to the owner.
Thankfully, Norlin had the foresight to make the neck from maple, so the guitar was completely undamaged. I've loved Norlin maple-neck Les Pauls ever since - and I have never again picked up a guitar case without checking that the latches are closed.
