The best solution is to replace the block with a steel one with a nylon insert, which will also improve the tone and resonance of the guitar, but it’s not the cheapest option.
https://reverb.com/uk/item/11886397-callaham-trem-block-us-vintage-repro-ca21015?gclid=Cj0KCQjwwIPrBRCJARIsAFlVT8-GSunu6TCOYaAyKrkeClp8LMvpr1tLd6TFz6AqwO7P62NIaKdyBW0aAiBgEALw_wcB&gclsrc=aw.ds&merchant_id=122264673&pla=1&utm_campaign=1726164661&utm_medium=cpc&utm_source=google
FITS FENDER ORIGINAL 1954-1969; US REISSUES; HIGHWAY 1 (THROUGH 2005); CUSTOM SHOP TIME MACHINE SERIES; JIMMIE VAUGHAN STRAT; ERIC JOHNSON STRAT; ROAD WORN STRAT; MIJ REISSUE (CIJ REISSUE REQUIRES TOP PLATE); CLASSIC SERIES '50S/60S/70S; WD EXACT VINTAGE
Should probably fit mine, but is there any cheaper options? Or is it worth getting a good one?
If it's angled back, don't remove the arm to put it in the case - just swing it round so it's pointing towards the strap button. This is why Leo Fender designed it with the angle! The vertical hole is a modern bodge on cheaper bridges.
If it does have a vertical hole that's even more reason to replace it with a proper steel block.
Callaham are good but very expensive. There are UK suppliers, including @FelineGuitars now - just make sure you check the dimensions, as non-vintage Strat bridges vary! Although I think the MIJ reissue ones are USA spec.
Many guitars have a re-sale value. Some you'll never want to sell.
Stockist of: Earvana & Graphtech nuts, Faber Tonepros & Gotoh hardware, Fatcat bridges. Highwood Saddles.
Expert guitar repairs and upgrades - fretwork our speciality! www.felineguitars.com. Facebook too!
https://www.thefretboard.co.uk/discussion/158767/
Band Stuff: https://navigationofficial.bandcamp.com/album/silhouette-ep
Frankly, I still don't understand why Fender don't use a similar system on Strats - the spring thing is a bodge IMHO and doesn't work as well. But I guess they make a good living out of selling replacements for when they fall out and go missing...
