Fret Levelling tool of choice ?
What’s yours ?
I have a huge stewmac beam that can be used with self adhesive sandpaper but it’s enormous and unwieldy and the sandpaper is expensive and hard to find.
I also have a crimson fret levelling file, very well made, and nice size, but I find it leaves tool marks on the playing surface of the frets that I can’t get rid of.
Maybe a diamond file of around the same size would be better ?
  • randellarandella Frets: 4185
    A cheap Wickes spirit level, one side face of which is a) just wide enough at 20mm or so, and b) impossibly true for a £10 tool.
    I use the Stewmac levelling bar & their fret files.
    I then polish with high grade sandpaper and then micro mesh.
  • NelsonPNelsonP Frets: 3400
    Gibson use one of these.....
  • RolandRoland Frets: 8724
    If I were looking for a new one then this is what I’d look at. The H section makes the structure very stable, and being aluminium it’s light to handle
    Until it wears out (ie after my lifetime) I’m using a fine toothed metal file blade. Not a cheap B&Q file, but a proper engineers metalworking file.
  • @NelsonP proper LOL. I bought a Martin OM-42 and I think they use a catapult a a brick "plek" is fucking wank. I've played 13 guitars with that and if I hadn't played a guitar with proper hand finished polished frets, I'd be pleased but for the money and supposed accuracy it's shite. The R9 I have was mostly "OK" but not good tech grade (I can't say "luthier" unless they actually make and adjust acoustic instruments, however a good tech is like a wizard)
  • SargeSarge Frets: 2419
    I use the Technofret 19" levelling beam from ebay iirc, they also sell the adhesive sandpaper strips at 240 and 320 grit, excellent stuff.
  • JayceeJaycee Frets: 310
    I got a pice of 16" aluminium box section simillar to  the technofret and trued it up on a piece of 6mm glass with wet and dry. Cost me £3 plus the paper
  • lysanderlysander Frets: 574
    edited September 2019
    I think there’s an argument for using a smaller tool like the Crimson files as opposed to a long beam / box section / spirit level, since the smaller ones don’t require the neck to be perfectly straight on its whole length when levelling but only locally straight.
    This should give a bit more room for error ( ie non flatness / straightness of the neck ) when levelling and shouldn’t really matter for playability since the neck is never completely straight when under tension.
    Discuss ?
  • KalimnaKalimna Frets: 1540
    I use a rectangular piece of 8mm glass (bevelled edges from glass merchants) that I spray glue wet-n-dry to. Cant remember which grit, but you can change as you like. The glass was cheap, it can be any length you want (mines about 7-8"x3"), and you can use any abrasive paper you have access to. It is also perfectly flat (at least as far as frets go. This is the way I was shown at Bailey guitars.
    Adam
  •  I use Steve Robinson of this parish (although I'm not sure that he'd be too happy about being referred to as a 'tool') :)
    Adam
    That’s a cool idea!
    lysander said:
    Adam
    That’s a cool idea!
    Cheers - cant say its mine tho!
    Often simple ideas are good ones, and efforts to over-engineer/complicate things dont do the job any better, just more expensively :)
    Adam
    edited October 2019
    I ended up buying this file which I stumbled upon and like it a lot - good size, very controllable, quite quick but leaves a smoother surface than metal files.
    https://www.chrisalsopguitar.co.uk/shop/guitar-tools/fret-levelling/Diamond-Fret-Leveller-File-TF020
  • SteveRobinsonSteveRobinson Frets: 7039
    I've been called worse :)
    StewMac beam for me with strips of abrasive attached using double sided tape.
