Replacement tuners for squier bullet mustang?
Looking for advice on decent tuners to upgrade the stock squier ones. Seen a lot of people say they've done it but struggling to find suggestions if which to look into getting. Anyone able to recommend some that'll do the job?
  • What diameter and depth are the holes drilled through the headstock to accept the original machineheads?
    Do you have the tools and confidence to ream those holes to a wider diameter?
    Chances are, a set of replica Kluson safety tuners would fit without major modification. If the stock 'heads are fastened with either rear-facing pegs or a locator lug and screw, these holes may be left visible after the upgrade.
  • SteveRobinsonSteveRobinson Frets: 7077
    edited September 2019 tFB Trader
    The tuners on there should be perfectly fine.
    If you want to replace them though, any 6-in-line 135° keys* such as these Gotohs should fit.
    https://www.allparts.uk.com/products/tuning-key-mini-6-in-line-gotoh
    * 135° is the angle of the fixing screw
  • ICBMICBM Frets: 72619
    Why do you need to change them? The stock ones are fine.
    At least 95% of all tuning problems are caused by things other than the machineheads, and when you've already got proper diecast/threaded-collar ones, probably at least 99%.
  • paulnb57paulnb57 Frets: 3073
    I have one which Ive modded, as stated the standard tuners are fine, I changed mine for lockers as I had them kicking around.....same as these
    http://www.axetec.co.uk/guitar_parts_uk_037.htm
    the MH606
  • Nut job. Specifically, flaring out the string slots with the appropriate files.
