Pedaltrain height
HAL9000HAL9000 Frets: 9779
Could do with just a few mm extra on the feet as the T-Rex junior velcroed underneath is starting to look rather worse for wear. Unbelievably the feet are riveted on rather than the more sensible option of using screws! Rather than drilling out the rivets and starting over I’m thinking of extending the rubber feet a tad. A bit of Googling suggests that Heyco part c2008 could be glued on to the existing feet - just wondered if anyone here has done this and if it worked out ok? Thanks.
  • NelsonPNelsonP Frets: 3412
    Get one of these and drill out the old ones with a 5mm drill. It's easy peasy.
    https://www.andertons.co.uk/cioks-mounting-kit-pedaltrain-mounting-kit
  • BeexterBeexter Frets: 617
    B and Q do some black rubber chair feet that i have just pushed onto the original pedaltrain ones. No glue needed. Diall is the brand name. They come in a variety of sizes and i can't remember what diameter i got but they work well and don't need you to mod the board in any way
  • HAL9000HAL9000 Frets: 9779
    Thanks. The B&Q solution sounds like the cheap’n’easy option.
    edited September 2019
    If anybody is interested it's the 18mm ones. £1.12 for a pack of four. Works a treat.
