Could do with just a few mm extra on the feet as the T-Rex junior velcroed underneath is starting to look rather worse for wear. Unbelievably the feet are riveted on rather than the more sensible option of using screws! Rather than drilling out the rivets and starting over I’m thinking of extending the rubber feet a tad. A bit of Googling suggests that Heyco part c2008 could be glued on to the existing feet - just wondered if anyone here has done this and if it worked out ok? Thanks.
https://www.andertons.co.uk/cioks-mounting-kit-pedaltrain-mounting-kit
