Speaker Mod
Hey all its my first post here.
I came across this cool mod I intend performing on my trusted Marshall Code 25 to hook up to my 4 X 4 speaker cab.
https://www.youtube.com/watch?v=5reuzceNOZ0&list=PL6VLcy_Vd29EBpkQd5_cXWs9yNII7vlBV&index=2&t=0s
does anyone know the name of this female jack plug and where i can buy one in preferably Europe?
cheers
  • phil_bphil_b Frets: 2010
    https://www.allparts.uk.com/collections/connectors
    You might find the right connector here
  • ICBMICBM Frets: 72409
    They're made by Cliff - there are copies, but they're not as good.
    You need a mono, switched, solder loop one. They're available on Amazon and Ebay if you can't find one locally.
    https://www.amazon.co.uk/CL1160A-Socket-female-switch-angled/dp/B013RJ875K/ref=sr_1_5?keywords=cliff+jack+socket&qid=1569485179&s=gateway&sr=8-5
    https://www.ebay.co.uk/itm/6-35mm-1-4-Panel-Mount-Mono-Jack-Socket-CLIFF-ELECTRONIC-COMPONENTS/133168331841?epid=20007738958&hash=item1f01737c41:g:BdEAAOSwZuxdeTIs
    Make sure you check the impedance of the amp's internal speaker and the cab first - if the cab impedance is lower than the amp's speaker, you could damage the amp.
  • adaminoadamino Frets: 128
    Thanks for the info.
    I am looking at getting the 6 pin so i can use 2 spaeakers. I love the fact that the speaker will disengage when changing from combo to a 4 x 4 cab as explained in the mod.
    The number of pins makes no difference to the number of speakers you can use - it's a mono output regardless. Don't use the 6-pin jack, it increases the risk of shorting the amp's output if you put the plug in when the amp is on, which could damage it.
    This thread keeps reminding me of John Bercow & Brexit - I've got it bad haven't I ? :'(
    Feedback
    OOOOOOOOOOOOOOOOOOOOOOOODERRRRRRRRRRRRRRRRRRRRRR
    edited October 2019
    did this yesterday  on a Marshall Bass 12 combo - used Neutrik NMJ4HC-S 1/4" Mono Jack Socket Switched Panel Chassis Mount 6.3mm Chrome - available ebay n others CPC
    Bass 12 sounds a rather good through a 4x12 :-)
    Thanks for the headsup
    Yes, they do don't they .
    does this jack disengage the 4 x 4 and engage the speaker on the combo when unplugged?
    edited October 2019
    in my case the 4x12 - but yes
    amp wiring to internal speaker acts as normal until you insert plug into the switched jack socket - then combo speaker is disengaged and output goes to  your speaker cab of choice .. Remove the inserted external jack lead and output goes back to internal speaker.
    - as a word of caution - ensure amp is switched off when performing the swap from internal to external speakers and vice versa to avoid any issues.
    That's great.Thank you very much =)
