Sample wars...
So  what sample rates and buffer sizes are we'r all using when recording and mixing?
I can only get away with:
Record
44.1khz
256
Mixing
44.1khz
1024
  • stratman3142stratman3142 Frets: 2202
    edited September 2019
    I use the same settings for record and mixing on my PC which are:
    44.1kHz
    64 spls
    It's been a while but I think I have to back off a bit on my laptop, which I use when I'm on holiday. IIRC that's the same sampling rate but either 96 or 128 spls.
    It's not a competition.
  • octatonicoctatonic Frets: 33826
    I mostly work in Pro Tools HDX so it doesn't matter what I use, latency is 0.8ms at 96k.
    If I do native then 48khz at 64 or 128 samples for tracking, 96k at 128samples.
    For mixing it is 48khz 512samples, 96khz 1024 samples.
