WTB: Crowther Hotcake
WazmeisterWazmeister Frets: 9619
Anyone got one to sell ?
Cheers :)
  • make sure you one with the bluesberry mod.
  • WazmeisterWazmeister Frets: 9619
    Why is that Jack ?
  • You want one with the internal dip switch that switches between std and bluesberry modes. The latter is a bit smoother, but it’s a pretty subtle change. I think they’ve all had this switch for at least 10 years, maybe longer.
    Cheers for the info :)
  • Fantastic pedal! Coaxed some of the tastiest lead tones I’ve ever heard from a single pedal and that was through a PRRI - But have to admit I struggled to get a pleasing light gain out of it, gain past two o’clock sounded phenomenal. They are supposed to sound glorious through a Vox.
    We’re probably discussing this in the wrong place, but....
    yes it isn't all that special at low gain and has a nasty sputtering decay at the end of the note that I couldn’t unhear! I thought it was just mine but apparently it’s a thing.  At or over about 2 o’ clock on the dial it’s got a wonderful saggy sustain, but it can disappear in the mix if you don’t set the presence control right.
  • BroccoBrocco Frets: 90
    My Crowther Hotcake sounds fab through my Matchless - I found the first post in this thread very helpful in setting up my HC to taste:
    https://www.thegearpage.net/board/index.php?threads/crowther-hotcake-i-figured-it-out.1733037/
    That's my thoughts as well, as a NAD Matchless Nighthawk owner... appreciate the link :)
  • selexisselexis Frets: 50
    Crazy, I use it NOT to get lost in the mix :) The Presence is a perfect (high) mids boost and I love it with gain around 11 o'clock. Now go, get one!!!
  • Anyone got one to sell ?
    Cheers :)
    One on eBay right now
    Cheers :)
    Cheers mate
    Got one, but I'm that impressed that I could well need another :)
    So, still looking...
    2reaction image LOL 1reaction image Wow! 0reaction image Wisdom
  • HoraceBHoraceB Frets: 337
    Looks like you may need a double Hotcake!  :)
    edited October 2019
    You may have read my thoughts...
    My recollection is that the double HC is not quite as versatile as two single HCs used together, as the double has a bluesberry and non -bluesberry side that I think are fixed, unlike single HCs. May not be an issue for you depending on which HC flavour you prefer.
    I seem to recall that too.
