NGD: My perfect Strat
lysanderlysander Frets: 574
edited October 2019 in Guitar
So I wanted to build a strat with some specs that you can’t really find and building it from scratch was a bit outside of my comfort zone as I wanted it spotless.
I got the body and neck from @GSPBASSES who did an amazing job, and finished it with milk paint, wipe on poly, oiled neck, Wilkinson hardware, Fender hot noiseless pickups and PTB ( treble cut and bass cut ) wiring.
Body is ash, the neck is 3 piece maple with Santos rosewood.
It’s a wide neck with a fairly flat radius and big frets.
Sounds and plays like a dream, I’m super happy.
The PTB wiring works exceedingly well
with the fender pickups, goes from big and punchy to vintage or smooth.
0reaction image LOL 16reaction image Wow! 0reaction image Wisdom
  • Mark1960Mark1960 Frets: 326
    Nice guitar
  • axisusaxisus Frets: 28341
    Wot, no pix?
  • PC_DavePC_Dave Frets: 3399
    axisus said:
    Wot, no pix?
    There are two....
    This week's procrastination forum might be moved to sometime next week.
  • SassafrasSassafras Frets: 30301
    It'll be fine once you sort out the trem springs.
  • lysanderlysander Frets: 574
    You don’t like naked springs?
    I never put the back covers on my tremolo guitars, as I find I have to adjust them often enough for it to be a pain.
  • merlinmerlin Frets: 6718
    I suspect he means put them on straight....
  • TeyeplayerTeyeplayer Frets: 3246
    I’ve always had the irrational fear that I’d be the victim of a freak spring based accident. The back of strats just seem to hang at a worrying location. Just saying.
  • tekbowtekbow Frets: 1699
    Love the neck joint. Zero excuse for a strat with a big block heel these days.
  • That's gorgeous lovely job!! Wow awarded.
    Diagonal gives more tension and is pretty standard.
    You sure about that?
    I'd have thought it makes the middle one redundant.
    I'm not sold on the stark white pickguard personally. Nice neck joint!
    edited October 2019
    Yes the outside ones have more tension than the middle but the total tension is still the sum of the three. I’ve had / seen plenty of guitars come this way from the factory.
    @axisus it’s vintage white, I can see what you mean on the photo, it looks less stark in real life.
    Thanks for all the nice comments !
    I've heard people say fanned springs look cooler than straight springs.
    What sort of lunatic stares in awe at the trem cavity of their guitar?
    Your audience certainly won't know unless you habitually play guitar with your teeth a la Jimi Hendrix.
  • tony99tony99 Frets: 7130
    I can tell the difference simply by hearing a few chords strummed on either to be fair.
    Bollocks you don't know Bono !!
    * Hamer Watson, SS2, Vintage S, T62.
    * Music Man Luke 1, Luke II
    Please drop me a message.
    15reaction image LOL 0reaction image Wow! 0reaction image Wisdom
  • bwetsbwets Frets: 162
    Angling the spring does not give any more (useful) tension. The tremolo resists the sum of the vertical tensions in the springs. When you angle a spring you split the total tension into horizontal and vertical parts. The horizontal part is of no use and the vertical part affects the tremolo.
  • JetfireJetfire Frets: 1696
    Holy shit that's pretty!!
    it makes the soundwaves vibrate diagonally as well as verically
