I managed to make a favourite switch recently - https://www.coda-effects.com/2015/02/strymon-favorite-switch-diy.html
And heres the original multiswitch instructions - not made yet - https://www.reddit.com/r/diypedals/comments/axzq00/how_to_build_your_own_strymon_multiswitch_or_line/
Hello John,
Thanks for supporting Strymon!
If both pedals are connected to a MultiSwitch Plus in Bank Mode, there is no way to select just one pedal to listen to the MS+, any connected pedals will respond to commands from the MS+. I believe that is what you are asking, but let me know if I am mistaken.
Please also keep in mind in Bank Mode, the middle switch alternates between the presets in the bank. On BigSky there is 3 presets per bank, on Timeline 2, so they might not always synch up.
Please check this out and let me know if you have any more questions.
Gohan Ruiz
Customer Support
Strymon Engineering
