Hi everyone,
Not sure I can fight this GAS for bass pedals much longer… ) I’ve tried a bunch of my guitar pedals and they sort of range from “That’s not too bad, I reckon I could get away with that,” to “Ewwww that’s horrible!” )
Cheaper is better, as long as it’s not garbage- it needs to sound good and not break if I look at it funny (though absolutely bomb-proof reliability isn’t needed as it’s only for home use, at least at the moment). I don’t use pedals all that much, and don’t need tons of bells and whistles (I normally just set and forget), which is why I don’t want to totally break the bank with them.
I think I want a fairly saturated fuzz/distortion, an
envelope filter for funky stuff, and an octave.
I was thinking about the EHX Bass Big Muff- I already have a Biyang (guitar) fuzz, which as far as I’m aware is more or less a Muff clone, and it sounded pretty good but the bass was a bit wooly on it and I’m hoping the bass version might help with that.
For the other two I was thinking of the Bassballs and the Octave Multiplexer (both EHX).
Are there any other good-sounding, reliable, reasonably-priced options which might sound better for a similar amount of money (£40-£50)? Or anything I’m missing? I’m not too well up on bass kit so there may well be good but reasonably-priced manufacturers I’m not aware of. Palmer does an octave for a bit more than the EHX one but I don’t know anything about it. It also does Bass OD and Fuzz pedals, but again, I’m not familiar with them. I also spotted the EHX Bass Blogger but I didn’t really like its tone from the clips, the OD was a bit subtle and the fuzz not really subtle enough (plus I preferred the tone of the big muff for the really saturated fuzz stuff). I’m aware of Behringer but I think that’s maybe cheaping out too much, even for me…
Thanks in advance for your help
Yeah, not sure about multi-fx... I'm always concerned they won't sound as good as separate pedals. Same with digital pedals (at least for overdrive and the like, for delay etc. it's fine). Just I already have enough guitar pedals that I'm sort of wary that they may already sound better than either a digital (but bass-orientated) or multi-fx overdrive will... Also my amp has a tube preamp (far as i'm aware), so I sort of suspect (maybe wrongly) that analogue pedals might sound better with that, for boosting etc. as well.
I'll keep it in mind, though. I have a couple of those x-series pedals for guitar and they're pretty decent- the delay especially. The chorus is a bit digital-sounding, though (which is why I'm a bit wary about the bass driver).
Thing is, I already have a bunch of guitar pedals (for modulation and the like) which I can use with bass. It's only really a couple of bass pedals that I'd really need, and I'd kind of want them to sound good. I don't use effects that much so a couple of good-sounding ones are of more use to me than a ton of mediocre ones. Though I might be being unfair to multi-fx there.
Interestingly I don't think the G3 sounds as good, and I don't know why yet.
Thanks. Yeah, that's kind of my concern. I already have a bunch of guitar pedals which can do double duty if I really need them (modulation and delays etc.), and I suspect they'd likely sound slightly better than the multifx, too. It's only really the dirt where I need a bass-orientated pedal. I don't currently have an envelope filter or octave so that's why I'm looking at them too. I'm just not sure that, when I already have a bunch of pedals and only need a couple, a multifx is really the way to go.
Thanks. I think from what I've read online that my amp already does a pretty decent SVT-type tone- it's a Genz Benz Streamliner 600 (I should've listed my current gear, I had the thread ready to go and then it wouldn't all fit in the one post and I just got sick of it and gave up ) ).
I asked this question on another forum as well and the (er, one) reply I got said the bassballs wasn't that great any more, and that the EHX octave multiplier might not work how I want (there's a vid on the EHX site where it's used with bass too as far as I'm aware). So I'm wondering about them, now. Will likely hold off on those, just in case.
He said the digitech synth bass wah was pretty good, and the price is pretty cheap. Digital, as far as I'm aware, so not sure about that. But it does seem to have a much bigger range of tones than the bassballs. And at ~£30 it's not going to be the end of the world anyway.
The B3 seems to be £110 on Thomann... I can get that "pedal or two" for less than that, lol. And which, according to ICBM, will likely sound (at least a bit) better.
I'm probably a bit anti-multifx because I know I don't use effects all that much (so a few good-sounding ones which I will use are more useful to me than millions of mediocre ones), and while I'm not anti-tons-of-knobs, I do tend to set and forget at the same time, and a multi-fx with tons of menus etc. isn't normally that helpful in that respect.
I realise this is starting to turn into that Fry/Futurama meme "Shut up and take my money!" (or more like "Shut up and let me waste my money!") )
Thanks Yeah that's what I've heard about the bass big muff- more or less a green russian muff with those extra modes, as you said.
Thanks for the info about the BB too.
Thanks, I'll check out the demo. And yeah it's not really to do with how easy it is to use, I kind of know what I'm like- even with single pedals I tend to set and forget, let alone twiddling multi-fx... )
EDIT: LOL yeah that sounds nuts. ) Yeah that's the kind of nonsense I want. Admittedly, in the clips I heard of the BassBalls, it was also the kind of silly noise I wanted. I get the feeling the BB is a one-trick pony, whereas the Digitech is much more versatile- but whether the BB does its sound better than the Digitech, I dunno.
Though if I did get the digitech would I be able to stop laughing long enough to actually play anything? Serious concern )
Wisdom awarded for those words!
