My thinking is if you wanted it on your board as your main fx unit but also to serve as a spare rig if your guitar or bass amp goes down, or just for sheer convenience at rehearsals,
And before anyone says it, I'm not interested in the HX FX (too big and wrong application given what I've mentioned).
I have a compressor and whammy that I run in the front, they work absolutely perfectly with the Stomp with no issues at all.
I have two delay pedals that I absolutely love, those go in the Stomp's FX loop so that I can move them around. I bought a 2 button switch from Bright Onion so I have five Stomp footswitches to play with to switch things in and out: but like I said I'm not gigging so its not desperately important.
On top of that, I tend to use the Stomp in one of two ways: either direct using an amp sim on the Stomp or I run it into the front end of a clean amp. In the latter case I tend to not bother running an amp sim on the Stomp and stick to FX only.
I have three dirt pedals that I've kept on the board (the Stomp ones are decent enough, I just already owned and liked these pedals and there's space so they stay on there). They work absolutely fine either in front of a Stomp amp sim or going into the amp via the Stomp.
Personally speaking, I'd absolutely recommend a Stomp, one of the best bits of gear I've ever bought. If gigging I'd be tempted to go for either an LT or a full fat Floor but that's because I hate faffing about with loads of gear. If you're attached to your amp and want a backup rig and a whole bunch of very usable effects on top then the Stomp is great.
https://www.brightonion.co.uk/mini-dual-momentary-footswitch/
You need to then set the controller settings in the Stomp to make it work properly. Its pretty easy.
NO 4CM. I don't have amps with fx loops.
I’m looking at this from the perspective of a gigging musician, I use mine with a power cab 112 plus which gives me a light weight versatile rig and I don’t need a separate pedal board.
Of course this is just one guys opinion
https://www.brightonion.co.uk/line-6/
