I have finally completed my Princeton kit build, bar from a couple of valves I need to buy.
However, I'm too damn scared to try turning the thing on!
I like being not dead, mostly.
Maybe I'll just use it as the "sure, you can jam with my band" reserve amp
Turns out there is an H in Haych! ~ Sporky
Bit of trading feedback here.
I might take you up on that if you don't mind bud? Swindon isn't very far away, probably about 45 minutes. This kinda thing definately calls for a 'thanks' fret.
Make sure you have a load connected.
If all is OK plug in and play. If you get terrible feedback reverse the connections on the OT primary. (is the Princeton push-pull with negative feedback, not sure?)
https://images.app.goo.gl/d7vYCiUofCubkLkZ7
