Learning by ear
HaychHaych Frets: 5654
One thing I've always struggled with; picking stuff off a record and learning it.  I'm better than I used to be but not as good as I want to be.
I'm currently trying to learn a solo, which isn't complicated, and I know I have the ability to play, but I just can't figure it out.  It's not helped by the fact that it's written in a harmonic minor key (I think), which is a bit alien to me.  It's not fast but it's taken me an hour to get the first bar.  So damn frustrating.
If I slow the track down it still isn't slow enough to pick out the individual notes and then you just get the sample rate confusing things too.
There must be an easier way of doing this, surely.  Or is it just a case of our old friend Percy Veerance?
Turns out there is an H in Haych! ~ Sporky
Bit of trading feedback here.
    Learning by ear is really learning by brain- the more you do it the better you get at recognising patterns.
    I don't slow things down when learning- I use Transcribe! to play the maximum number of notes I can recognise at once, finding them on the neck.
    If that is one note at a time then so be it.
    I did a video about how to transcribe music for the forum a while back, I will see if I can find it.
    Yes it is perseverance.
  • Break it up into phrases and try to get the rhythm of them first, makes it much easier to learn the notes after. If you can sing the solo you can usually play it, that's how I do it.
  • HaychHaych Frets: 5654
    I've seen people do that before, but I can't sing for toffee so that's me out. :/
  • sev112sev112 Frets: 2772
    When things start to get fast, I just can’t “hear” the rhythm!
    I can't sing very well either but I can use it to work out pitch.
  • Mark1960Mark1960 Frets: 326
    I think it's one of those things that the more you do the easier it becomes, as most simple solo's are based around either the melody of the song or a series of "standard" Licks or in some cases Riffs. I start by learning the solo in my head so I can hear in my head if the note goes up or down from the previous note. A basic knowlege of the chord sequence will also help as this narrows down the potential number of notes played over any one chord. If all else fails if it's a classic solo, you can often get a u-tube lesson. Just type in the solo name followed by guitar lesson, and you may find some demo's or TAB sheets. As you build up your repertoir, you will start to find sequences of other solos that you have already learnt, so they can easily slot right in there if the key is the same, but if not just transpose them. Good luck, and enjoy the challenge, it's all part of the journey.
    I can't sing for toffee either. I break things down into phrases also and then imagine/hear the phrase in my head.
    As has been said earlier, it's perseverance. Then you get to recognise certain phrases or combinations, and permutations of those phrases. However, I can only do that quickly with my largely blues/rock vocabulary. If it's some jazzy phrase I'm completely unfamiliar with, it's sometimes down to working it out very slowly.
    It's not a competition.
    Hey, @octatonic, I Googled the Transcribe! software you mentioned. Absolutely wonderful tool. Thank you for bringing that to my attention.
    I’ve only dabbled with it for an hour or so but in that time had worked out the first half of the solo I was struggling with.
    Thank you so much!
  • mrkbmrkb Frets: 6884
    Thank you so much!
    Its great software - works with videos as well - I often download a youtube tutorial and loop the phrase Im learning - slow it a bit to get the phrasing correct (and check how its being played in the video), then speed it up.
    Karma......
    Ebay mark7777_1
  • axisusaxisus Frets: 28339
    The hard part for me is memory. I can't remember tomorrow what I learned today.
  • jpfampsjpfamps Frets: 2734
    I use Transcribe too.
    I find the looping feature really helpful for nailing phrasing.
    Thank you so much!
    Most welcome.
  • vizviz Frets: 10700
    That’s not having poor memory, that’s just being bad at time travel.
  • DLMDLM Frets: 2513
    @octatonic Is this the thread you were thinking of, James? https://www.thefretboard.co.uk/discussion/85579/the-inaugural-learn-a-song-a-day-for-a-month-challenge/p1 Bostin' stuff! :)
    Yeah that was it.
  • For the Mac, I'd mention Capo - https://supermegaultragroovy.com/products/capo/
    Capo can kiss my rosy red ring.
    It looks like a great tool, I did download it and started using it and comparing it against Transcribe!  The interface is very friendly but after about a minute of using it Capo deliberately overlaid irritating white noise over the track I was using and flagged that it was because I was using the trial version.
    How on earth you're meant to be able to trial a piece of software that is deliberately functionally impaired is beyond me.  The only way to evaluate it properly without white noise is to buy a subscription.
    So, no, sorry, does look good but I won't be subscribing.  At least Transcribe! allows me a full 30 days to decide if I want to buy a license.
  • nickpnickp Frets: 183
    justin guitar has a bit on ear training I think - it's in the back of my mind as it's something I have to undertake and soon!
  • Danny1969Danny1969 Frets: 10424
    Reaper is actually very good as a translating tool and being non crippled evaluation software it's essentially free. Common tricks I use are
    Import song, right click and "Item processing" then  "explode multi channel audio to new one channel items"   ... then click the phase button on one of the new tracks. This will cancel out most of the vocal and bass and kick so you can hear guitars better.
    Highlight a section your learning and then hit the toggle repeat button so it loops the bit your interested in constantly
    To slow a track down without changing the  pitch hold down Alt and drag the right hand end of the track to the right
    To change pitch on old recordings where tape transfers changed the pitch slightly use the Playback Rate slider at the bottom of the edit window .... hold down Ctrl while moving the slider for more precise movements in pitch
    Insert the EQ plugin on a track and high pass it around 400Hz and lo pass it around 4K  to hear the guitars better
    There's probably more but I use the above all the time
  • menamestommenamestom Frets: 4720
    Find some dude on youtube that's done all the hard work.  Copy all the hardwork until you know the solo.
    Play solo at gig.  Spend the extra time you would have wasted on working it out on talking to the chicks who are mightily impressed with your solo.
    This works for me, except the last sentence, which was from my imagination.
