Is this a thing? "set and forget" guitar necks
  • sweepysweepy Frets: 4208
    bbill335 said:
    is this why aluminium necks were developed?
    The old Kramer aluminium necks used to move, albeit not a great deal
  • Graphite in the neck is great. Having a gloss poly finish helps massively, too.
    Possibly the more the truss rod is engaged, the less it’s likely to move? So, a guitar with heavy strings (or a neck with a little forward bow built in) tend not to move as much as the rod is helping a lot. Just a guess.
    I like a low action, light strings and as straight as possibly neck. Some of my guitars I can achieve this set up without them moving ever, others need tweaking all time. Those guitars stay at home on the naughty step and don’t come out to gigs.
  • blobbblobb Frets: 3043
    My Manson (1976), wood, neck-thru has been sitting out unplayed for about a month. Fully exposed to temp changes in a very temp change susceptible room. Picked it up last night and it was still perfectly in tune, as measured on a strobe tuner.
    My Alu neck Kramer bass (no truss) never moves. You move, the neck doesn't.
    Feelin' Reelin' & Squeelin'
  • CorvusCorvus Frets: 2969
    This time of year a few of mine want tweaks, some more than others. Old house and humidity & heating changes no doubt. I'm fussy about fairly low action and minimal relief so a change feel is easily felt.
    Quartersawn and cf rods should help but no guarantee, wood wants to move with moisture changes.
  • I agree with ICBM and others that recommend graphite/carbon fibre alternatives. Wood will move. I have a cheap plastic Switch guitar which is perfectly stable (a pity its so ugly and unloved).
    Some guitars need more frequent setting up than others. I sold on an Epi Casino Coupe only because it wouldn't settle at all and I got tired of all the constant adjustments.
    If I could find the right non-wood model, I'd go for it.
    I sometimes think, therefore I am intermittent
  • rossirossi Frets: 1710
    sev112 said:
    Blimey. I’ve got 7 guitars and a bass and never had to use the truss rod
    same here I have a Squier Joe Trohmann "tele" neck on my strat and despite a jammed nut that will never move again its held a low action without any need to adjust .In a cold room to super hot room .I set them up once and then thats it and I take em to hot bars ,cold car parks etc.
  • ICBMICBM Frets: 72778
    They have serious tuning problems with temperature changes though. I never understood why anyone thought they were a good idea, they feel dreadful too!
  • ESBlondeESBlonde Frets: 3596
    I think it's possible to have two similar guitars, one will be stable and the other not. Wood can be like that. I have a small sample to review that suggests older guitars/wood becomes more stable, but is that because they are treated well and looked after or because the cell walls crysallise?
    I'm a big fan of keeping guitars in thier proper cases and when they have travelled in a cold vehicle, I leave the case to aclimatise a short while before opening it rather than getting a cold/hot guitar out in a hot/cold venue. I have light strings and a very low action on my electric guitars, I can't remember the last time I had to adjust a truss rod once a guitar was set to my tastes. In fact my Aria PE1000 is the best most reliable playing guitar I have, the truss rod is untouched in decades and the guitar comes out of the case in tune more often than not irrispective of the last time it was put away.
