If so they're quite nice, although that one needs the intonation doing
The amp looks like a Rocktron Velocity V10, which will sound like a very angry hornet in a beer can
Hopefully, it is the thicker white single ply plastic with a bevelled edge rather than the thin white version that cracks and breaks if you so much as look at it.
There is an issue with the outline of some MIC Stratocaster pickguards. It reaches slightly further towards the jack socket plate than a regular Stratocaster. Hence, the majority of aftermarket replacement 'guards risk leaving the corner of the extended controls rout showing. Even when the cavity is covered, there may be nothing into which the screw in the corner can bite.
I must admit looking at it I'd noticed that the distance between the output and scratch plate looked a bit different but wasn't sure if that was normal on Squiers.
It will be nice to keep my hand in when I'm away though - and I will certainly set the intonation!
Thanks again all.
The other giveaway is that Affinitys have 'Strat', rather than 'Stratocaster', on the headstock.
