Do YOU know how a guitar amp EQ works?
13»
  • LastMantraLastMantra Frets: 3825
    edited November 2019
    Sassafras said:
    All amps are different so there's no magic formula.
    ICBM said:
    I find the idea of not using the full range of the controls quite odd. I don’t have any hesitation in setting any control to full or zero if that’s where it sounds best.
    Mine only have bass and treble...but yeah, definitely this. Use your ears not what someone else tells you will sound best!
    And don't be afraid to use them (full amount)...that's what they're for!
  • I find it simple...all my amps just have one tone knob
    Philtre said:
    Some people actually don't know what Bass and Treble are. I once sold an amp to a punter who wanted to know what the "Bass" knob was for. He pronounced it like the fish. I told him it helps to keep the guitar in Tuna.
    Sadly, that is a true story.
    He has to have been taking the piss surely.
    Can just about believe someone didn't know what treble meant but he must have heard of the instrument bass.
  • PhiltrePhiltre Frets: 4177
    It is actually true. His words were something like "Bass? Bass? What's that for?", as he pointed at the knob. As I said, pronounced like the fish. Maybe he was dyslexic? He was certainly a newbie to guitars and amps. I do but report the incident. :-)
    Just watched a Youtube video where 6 top amp makers have to tweak each other's amps to get a good tone (then vote for the best and try to recognise their own amps).
    Dave Friedman says that people might not want to hear it but there's no formula to follow, you just have to listen and use your ears.
    Not only that but it's obvious that when they tweak they are just turning knobs and flicking switches, hearing what it does then adjusting.
  • FezFez Frets: 537
    welshboyo said:
    So..that Matt Schofield technique - how do you do it - do you start with Bass Control (all others at 0) and find the sweet spot, leave it there and move on to the Mid etc etc or do you start with all at 0, find the sweet spot for each one, remember them and then set at end?
    The way I was shown years ago by a Fender demonstrator was this:
    Zero the Bass Middle and Treble controls. Set the volume and gain if you want it.
    Play a first position open E chord and turn the bass knob until you here the peak where the sound seems jump into focus.
    Then do the same for the middle control but play an A chord and for the Treble but play a D chord.
     That should give you a good basic sound which can then tweak to fit the situation. For instance you might want to reduce the middle in a band mix if you are playing rhythm guitar parts.
    Don't touch that dial.
  • sev112sev112 Frets: 2814
    For all of these methods, where is the Tone on your guitar while twiddling amp knobs. Is also halfway , or full on?
  • ICBMICBM Frets: 72769
    Volume and tone full up. You need to hear the full range of frequencies from the guitar.
  • ennspekennspek Frets: 1626
    Do you have a link? Sounds interesting.
  • bbill335bbill335 Frets: 1391
    i tend to set it up so that 8 on the guitar's vol/tone is "enough", and i know there's more in the bank if i need it
    https://www.youtube.com/watch?v=hnRIWxCdU6I
  • This is the first time I've heard of techniques for settings amp tone controls.
    Weird.
    Weird.
    I think maybe the reason some look for a "technique", and still even search for one after many people say they just have to listen, is that they can feel overwhelmed by a lot of controls and might not have the confidence to trust their ears so they want set steps to follow.
    I suppose it would seem easier if someone followed "after steps 2 and 3, now turn the bass control clockwise until the bass sounds like *adjective*". Then they're moving a specific control with a specific goal rather than not knowing which knob to turn first or when to stop turning it.
    It really does just take time to get used to what the knobs each sound like though.
    It's remarkable how effective the technique of turning each control until you find the spot it does the most over the least turn is - I didn't believe it myself until I actually tried it.
    It might not necessarily give you the sound you want - not helped by there sometimes being more than one point where the control does a lot - but as a quick way to get a workable sound and see what the amp inherently 'wants' to do it's extremely useful.
    Weird.
    Maybe it's because I only have bass and treble controls...but I do still have pedals with tone controls.
  • RockerRocker Frets: 5003
    Switch off the tone stack ['Cookin' setting on my Stinger].  Turn up the amp volume control.  Use the guitar volume control to 'adjust' the tone from the amp.  Even easier if the guitar has no tone control fitted [my Gibson Melody Maker has only a volume control, which is more than enough to think about].
    Nil Satis Nisi Optimum
    Thing is though a lot of amps now have controls that affect other controls, presence and deep being a good example on my VH4 but lots of amps have a similar idea like contour etc.
    ဈǝᴉʇsɐoʇǝsǝǝɥɔဪቌ
  • Funnily enough I once bought a Mesa Studio Preamp from a shop for an absolute steal, the guy in the shop said...” Yeah it says Mesa Boogie but it won’t do the Dream Theater sounds”
    I set it to the classic Mark series settings
    Bass 1-2 Mid 3 Treble 7-8 huge V in the graphic EQ and there it was, instant Petrucci (well tonality wise anyway)
     I’m guessing they had been setting it with everything on 5 and wondering why it sounded so flubby and mushy.
