Floyd version installed on Charvel Guthrie ?
no experience with either but do seem to be attempting to address the any string movement in block - assuming well cut nut or roller and locking machines n stretched strings n spring / claw set correctly - should be as near perfect as possible ?
The modern Wilkinson is great, and affordable. The non fine tune floyd rose or the new Wilkinson locking one in theory should be even better.
It’s dive only which doesn’t help you directly, but these are not talked about much in the UK so it’s interesting.
Another option might be https://www.super-vee.com/
Again pretty unusual.
* Hamer Watson, SS2, Vintage S, T62.
* Music Man Luke 1, Luke II
Please drop me a message.
You have to lock the string in the blocks, but it stops any string slip etc
Old Guthrie Govan has one on his signature Charvel model, so if he likes them etc etc
