Plugging the selector switch hole on a white firebird pickguard
Any suggestions?
I've stripped out everything except 1 volume and the switch, which I've moved the body cavity. I filled the empty pot holes with white screw covers, which fit perfectly, but they're too small for the hole in the pickguard. Looking for something plastic and white.
Many thanks!
  • bbill335bbill335 Frets: 1391
    is it one of the circular toggles like on SG/Jazzmaster/etc? you can get a short hex bolt and appropriate nut which I've seen used to blank holes quite smartly. just make sure the head of the bolt is bigger than the hole.
  • Yeah it's just a round hole - excuse my ignorance but what do you mean by a hex bolt?
  • ICBMICBM Frets: 72932
    Ikea. You get covers like that for bolts in flat-pack furniture, including 12mm which is the size you need.
    check out this post on instagram to see what i mean
    see how the empty pot holes have a domed allen key/hex bolt instead of the empty hole?
    You'd need to buy 25, but it still comes to only just over £3...
    https://www.ebay.co.uk/itm/plug-fixing-holes-blanking-plugs-plastic-cover-finishing-inserts-hole-cap-round/113378193072
    I'd probably get the 13mm rather than 12mm since the hole will probably be 12.7mm (1/2") and it's better tight than loose.
    That's exactly what I'm looking for, thank you!
