Brilliant woodworking hack: The Ticking Stick
I just chanced on this video about ticking-sticks.
I've never heard of this device before but it's a simple quite genius idea for accurately marking up difficult shape for cutting.
You learn something new ever day.
0reaction image LOL 1reaction image Wow! 3reaction image Wisdom
  • axisusaxisus Frets: 28353
    Not sure what it is? I couldn't be bothered to watch 7 minutes of video, jumped a couple of times and I'm still confused. Life is too short to engage with everything. Next!
  • Adam_MDAdam_MD Frets: 3420
    That is genius
  • phil_bphil_b Frets: 2011
    piece of paper and a dirty thumb
  • SteveRobinsonSteveRobinson Frets: 7097
    edited November 2019 tFB Trader
    what I read
    5reaction image LOL 0reaction image Wow! 1reaction image Wisdom
  • poopotpoopot Frets: 9099
    Put sheet under hole...
    draw round hole...
    cut out shape...
    seems a lot less agg to me
    what I read
    Funny enough I also read tickling every time until the guy said 'ticking' in the video. It sure looked like a weird tickling stick.
  • octatonicoctatonic Frets: 33896
    This is one thing worthy of seven minutes of your time.
  • ROOGROOG Frets: 562
    Not heard of that before, neat idea, I shall try to apply it in future
  • merlinmerlin Frets: 6813
    axisus said:
    what I read
    The woman in the video is called Leah Bolden and she's got a whole tonne of amazing DIY/building tips available via her youtube channel "See Jane Drill".
  • FunkfingersFunkfingers Frets: 14718
    what I read
    I, too, expected this Discussion to be the work of RandallFlagg ... not least because of the single entendre humour lurking in the YouTube video channel name.
    "See Jane Drill" sounds like a porn site.
  • DrBobDrBob Frets: 3012
    It only really works for straight lines though right ? A curved hole wouldnt really work with that stick ?
    Not at all. It would be shit, unless you used it to draw the arc.
    DrBob said:
    It only really works for straight lines though, right?
    The stick can be used to register any shape. A curved shape would just require more reference points. An simple arc would be easier to mark with other tools.
    The only critical stipulation is that the surface on which the markings are to be made should not mask any of the corners of the shape being copied.
    The video mentions boat building. I suspect that the ticking stick could also be of use in stone masonry.
  • equalsqlequalsql Frets: 6224
    Trust me, you really do need to watch it.. there's this lightbulb moment when you suddenly realise wtf, that's brilliant!
  • JD50JD50 Frets: 662
    OK, fl;ipped through the vid and I can see what he was doing, but I just can't see the point. He could have stuck the flat bit underneath and drawn around the shape in about 4 seconds.
  • Danny1969Danny1969 Frets: 10507
    Agreed but what if the wood was stuck on the wall and you can' put anything underneath ..... this often comes up when your plasterboarding attic rooms with sloped walls due to the roof.
    Check out this video of it being used to fit shelving tight against a uneven wall.
    An interesting take on scribing in, I was taught to do this with a compass & a pencil.
