112.8mph Lucky Poos Needed
  • RiftAmpsRiftAmps Frets: 3171
    edited November 2019 tFB Trader
    Oil Pump
    As mentioned earlier, the B6 engine was used in several cars by Mazda. The Oil Pump has a few holes/galleys/passages that are used in some, but not in others. We need to block one of these off. It's the dipstick hole for the 323F. A small blanking plug is coated in RTV, then pressed into place.
    Then a small O-Ring is fitted...
    ...before RTV is applied to all mating surfaces. The pump came with a paper gasket but I prefer to use RTV if I can.
    Next up we lube up the crank pin...
    ...before sliding the pump into place. Dowel pins help locate it in the correct position.
    Finally, the six bolts are inserted and torqued in stages to 26Nm.
    Rift Amplification
    Handwired Guitar Amplifiers
    Brackley, Northamptonshire
    www.riftamps.co.uk
  • Emp_FabEmp_Fab Frets: 24344
    Loving this!  BTW, when I mentioned water injection earlier, I didn’t mean in relation to the cooling system.  I meant into the intake manifold - as in performance boost.
    The provisional calendar was announced today - No Oulton Park but Anglesey is a great shout, any circuit with big elevation changes are fun to drive.
    Rift Amplification
    www.riftamps.co.uk
    Pistons
    Each piston, gudgeon pin, conrod, bearings, and piston ring assemblies have been weight-matched to the nearest gram, then balanced with the crankshaft as a whole rotating assembly.
    The first task after a thorough cleaning is to install a locking clip into the front side of the piston
    Then the piston, small conrod end, and gudgeon pin and coated in assembly lube
    The pin is then pushed in from the rear of the piston...
    ...through the conrod...
    ...and all the way through.
    Another clip is fitted on the other side.
    And that's it. Rinse and repeat three more times before wiping off excessive lube.
    Piston rings are next.
    Rift Amplification
    www.riftamps.co.uk
    Helmet arrived back today from the painter. Mega happy with it :)
    Rift Amplification
    www.riftamps.co.uk
    edited December 2019 tFB Trader
    Mallory Park - 26th December
    Sod it, I've entered the Plum Pudding races on Boxing Day at Mallory Park. Nick isn't available so I will be doing both of the 15-minute sprint races. As I only did 1 race start this year, it'll be a great opportunity to practice.
    Mallory Park is where I took my race license test, so looking forward to going back and really attacking the circuit.
    About the Plum Pudding Meeting
    While the main racing season usually concludes around late October to early November, that doesn’t mean that any and all opportunities to wheel the race car out of the garage one more time have dried up. Far from it, as there’s still one event that is the perfect chance for racers and petrolheads alike to celebrate the festive season in the best way possible – getting out on track!
    Once again, the BRSCC is delighted to be at the helm of the car element of the annual Plum Pudding Races at Mallory Park, a traditional event that takes place on Boxing Day (December 26th) every year allowing some drivers and motorsport fans a great chance to indulge in their favourite pass time during Christmas!
    There are separate grids and races for both saloon cars and sports cars respectively, but both play out a little differently than conventional race meetings. Unlike those in the regular season, there are no qualifying sessions here. Instead, the fastest race entry sets pole position rather than fastest lap time. So if you enter first, you get pole position for Race 1. The results of Race 1 then set the grid for the second race with the entire grid reversed to further enhance the action.
    All race-ready sports cars and saloons cars are eligible to enter their respective races, with saloons cars ranging from Peugeot 206s, Ford Fiestas and Honda Civics, to Alfa Romeos, Ford Escorts, BMWs and VW Golfs. As for sports cars, you can bring vehicles such as Caterhams, Porsches, Radicals and other sports prototypes, Mazda MX-5s, TVRs and Lotus Elises. This really is an incredibly open contest, so as long as the car meets all the required Motorsport UK safety requirements, you’re in!
    As is the tradition, the Plum Pudding meeting will also feature bike races organised by the East Midland Racing Association. More details can be found at https://www.eastmidlandracing.co.uk/.
    Who's racing?
    - Saloons (2 x 15minute races)
    - Sports Cars (2 x 15minute races)
    - Motorbikes (2 x 15minute races)
    Prep
    Brakes - The rear pads were quite worn, so fitted a new set.
    Tickets
    From £11 each, children under 13 go free.
    Rift Amplification
    www.riftamps.co.uk
  • NiteflyNitefly Frets: 4919
    Bizarrely, that link takes me to the Silverstone 750 club website!?
  • CeeJayCeeJay Frets: 455
    I've graced that tarmac a few times, albeit on a bike. Is that Devils Elbow still scarily off camber? Looks a nice fast sweep on paper but it's caught more than a few out, me included!
    Weird! Fixed
    Rift Amplification
    www.riftamps.co.uk
    Yes! With a two bumps on the inside. My instructor told me drive around the outside of the corner to avoid them - seemed to work.
    Rift Amplification
    www.riftamps.co.uk
    RiftAmps said:
    Weird! Fixed
    Hooray, thank you!
  • rsvmarkrsvmark Frets: 1383
    Yes, it is a tricky one on 2 wheels. It caught me out on one occasion.....and once was enough- did enough damage to me, the bike, my wallet and my confidence!
    An official Foo liked guitarist since 2024
    Piston Rings
    Each piston is fitted with 5 rings - a top ring, a middle ring, and an oil control ring flanked by two, smaller control rings.
    The top and middle rings cannot simply be fitted directly onto the piston without first measuring the 'end gap'. Each ring has an opening that must be a prescribed width when installed.
    The first task is to fit the ring into the block
    Then is needs to be levelled about 1" below the surface. Using an old piston is perfect for this
    The gap is then measured with a feeler gauge.
    For a road engine, you're looking for 3thou for every inch of bore diameter, so approx 12thou or so. In a race engine we want slightly larger - 4thou per inch - so 16thou approx.
    They all measure 15 to 17thou, which is perfect.
    The rings are then fitted onto the piston and then the skirt, rings, and cylinder walls are lightly coated in oil.
    Rift Amplification
    www.riftamps.co.uk
    The pistons are then inserted into the block, #1 and #4 first, then #2 and #3.
    The bearings are fitted to the rods and caps before being coated in assembly lube
    The cap bolt threads are coated in ARP lube
    before installing and torquing in equal steps to 35Nm.
    Rift Amplification
    www.riftamps.co.uk
    Sump install
    Now that the crank and pistons are installed, we can button up the bottom end of the block. The first task is to install the oil pickup tube
    A new gasket sits between the pickup tube and oil pump
    As these bolts are only torqued to 11Nm, I used blue Loctite on the threads just to make sure that they don't come loose.
    The windage tray stops the crankshaft splashing around in the oil at the bottom of the sump. A bead of RTV is applied before fitting to the block
    There are two half-moon oil seals, one at each end of the block. They are held on with a little RTV
    The sump gets a good bead of RTV before being fitted to the block and each bolt is torqued to 11Nm in an outward spiral pattern
    Rift Amplification
    www.riftamps.co.uk
  • the_jaffathe_jaffa Frets: 1796
    Loving this! Thank you
  • FX_MunkeeFX_Munkee Frets: 2478
    Lovely work, just one question - no crank scraper?
    Shot through the heart, and you’re to blame, you give love a bad name. Not to mention archery tuition.
    Not on this one. We thought about it but I'm already massively over budget on the build and the gains are fairly minimal I think. Maybe when we go to ITBs?
    Rift Amplification
    www.riftamps.co.uk
    @riftamps This thread is rivalling one of Ash’s pickup rebuilds! Great stuff
  • Yes, I'm loving it too.  Very interesting.
