Leaking cylinder, time for a combi boiler?
124»
  • ICBMICBM Frets: 72642
    boogieman said:
    If one of the five outlets is feeding your shower you can get round that. There’s a thing called a Surrey Flange that screws into the top of the cylinder and provides a dedicated feed to the shower. Obviously it means adapting the pipework but it might get you out of a fix if you can’t find a matching cylinder.
    There's also an Essex Flange which goes through the side of the tank, which may be what's fitted to this one already. If so, it's the one that's leaking...
  • boogiemanboogieman Frets: 12426
    Ah right, not heard of that one.
  • KittyfriskKittyfrisk Frets: 18987
    I do love the word 'Flange'. Just saying...
    :)   Essex Flange does sound like a good description for Gemma Collins.
  • DominicDominic Frets: 16152
    Yes that is correct
    Or ......you could replumb the boiler to act as a system boiler and get a Megaflo type pressurised cylinder but much more expensive -worth it in the long run....more pressure ,etc etc
    Thankfully I had never heard of her & am now struggling to forget.
  • strtdvstrtdv Frets: 2467
    Dominic said:
    Yes that is correct
    Will your 20 year old plumbing designed with a non-pressurised system in mind stand up to the extra pressure or is that just asking for more leaks?
    pressure test it first but you'll be lucky to get 3 bar anyway which isn't that high but a great improvement
