Whats a decent marshallesque 20ish watts 1x12 combo ??
riffpowersriffpowers Frets: 344
While my mini 800 has been getting fixed I've been using a borrowed blues jr.
I'm not that keen on the sound, but I've been enjoying turning up to practices and gigs with a 1x12 combo.
I'm thinking of getting a 1x12 combo as a backup, and for times when I can't / don't want to bring  a head and cab.
What is a good quality marshally sounding 1x12 combo to keep an eye out for??
I'd have said the mini jcm800 combo but it's a 10" speaker.
  • sweepysweepy Frets: 4187
    Fargen ?
  • welshboyowelshboyo Frets: 1816
    My Atma...;-)
  • photekphotek Frets: 1463
    edited December 2019
    Origin 20c
    Jubilee mini combo
    Jet City JCA2112
    DSL20CR
    All quite reasonable second hand.
  • Fishboy7Fishboy7 Frets: 2200
    1974x
  • Laney Cub12
    Just so people are aware. I have no idea what any of these words mean.
  • TTBZTTBZ Frets: 2901
    Mini Jubilee...
  • soma1975soma1975 Frets: 6721
    Marshall Studio Vintage SV20c is fabulous. Especially paired with an attenuator. regardless of its 10" speaker.
    That said I have the head and a 1x12" cab.
    The 10” actually sounds fine if you listen with your ears and not the spec sheet. It’s a bit more focused than a 12 but still sounds good especially in a mix.
  • So the 10” speakers sound decent in the Marshall studio combos ?
  • ICBMICBM Frets: 72447
    There is no way it will sound as good as a proper 12” Greenback or G12H-30. It just won’t. Absolutely inexplicable choice by Marshall not to fit one.
    Whether there’s enough room to cut out the baffle and fit one, I’m not sure.
  • prowlaprowla Frets: 4930
    I've recently bought an Orange Micro Terror - it's separate amp and cab rather than a combo, but it is bloddy good!
    If there is then that might be the answer,
    I know Zilla (or someone) could probably make a new combo for it, but that'd be big money I;d think.
  • TwinfanTwinfan Frets: 1625
    Another vote for the mini Jube, given that you usually use a mini JCM800 it seems the perfect choice.
  • Looks like you can fit a 12" speaker in, someone on marshall amps forum has done it.
    You can just get a 12incher in the Origin 20, I nearly did it but bought a head instead, so now have both head and combo...
  • rze99rze99 Frets: 2292
    I've got a Genz Benz Black Pearl 30 1X12 combo that has power scaling. it can do an amazing impression of a Marshall.  Not made any more but they come up for sale once in a while and are incredible VFm because no one has heard of  them.
    It basically sounds the same as the SC20 on rhythm clip as well - you can dial them in almost identical.
  • John_AJohn_A Frets: 3775
    Had the origin 20 combo for a brief time and the 10” speaker sounded great, if you didn’t know it wasn’t a 12 you wouldn’t realise
  • thomasw88thomasw88 Frets: 2328
    I'm sure I saw someone on ebay a while ago who was putting 12inch speakers into the 20c.     Much modifications required to the baffle board?
  • gubblegubble Frets: 1746
    How about looking for a Peavey Windsor Combo ?
    Usually found very cheap and a JCM800 sound to it.
