Staggered or Flat Single Coils
  • RolandRoland Frets: 8704
    thegummy said:
    Don't know if anyone's ever done this but for soloing you could even learn to make conscious decisions about which strings you play notes on ...
    Lots of people
  • FunkfingersFunkfingers Frets: 14426
    ICBM said:
    The vintage high G stagger is easily the worst, both for string balance and for catching and breaking your pick or fingernails - I have no idea why anyone would want it on any guitar now
    Users of big, ol' string sets with a wound G, maybe?
    Retentive collectors for whom even present day replicas must look exactly like the original design.
  • ICBMICBM Frets: 72336
    edited December 2019
    I do actually use a wound G on many guitars - although not Strats - and I’ve never had a problem with a weak signal from it without needing such an extreme stagger. Halfway between the height of the B and D seems about right usually. (Bearing in mind that I set the D string physically higher than the G over the fingerboard too.)
    Bingo!
