Forum feedback thread. | G&B interview #1 & #2 | https://www.instagram.com/_harry_seven_/
http://www.thefretboard.co.uk/discussion/89942/caspercaster#latest
• Youtube - https://www.youtube.com/@Goldeneraguitars
You don’t need to be a super expert, the bare truss rod adjustment hole in the headstock is a dead giveaway.
There are many other smaller ones too.
Someone may correct me on everything I’ve just said but that’s my experience with Jap strats. They’re easy guitars to fake and all it takes is one unsuspecting buyer to come along and they’ll lose a few hundred very quickly.
It’s illegal regardless, since it says both Fender on the guitar and in the listing, so it’s a clear counterfeit with intent to deceive.
Also reported. The more that do, the quicker it will get pulled. Go down the list and select ‘copyright and trademark’, ‘counterfeit item or authenticity disclaimer’, ‘counterfeit, fake or replica item’ and state that it’s not a Fender and is a Chinese fake.
Who wouldn't take the time to remove the neck in order to ensure a higher price for it too...
He's not a musician himself, but tells us that it's a very well made and well playing instrument. OK...
The best thing to do is to get detailed pictures and compare them with pictures of genuine guitars and you can usually easily find some discrepancies with the fake.
The ridge separating the headstock from the neck on the back is too prominent.
The string trees are too wide (along the length of the strings).
The bridge is too 'square' at the corners where the trem arm hole is.
The bridge saddles are wrong.
The backplate is too square at the corners and the middle two screws are not offset.
The pickup polepieces are not staggered, and too tall for non-staggered (the two ways real Fender pickups are).
The pickup height screw heads are too small.
The pickguard tip on the lower horn is too rounded.
Compare any of these things to a real one and you'll easily see why they're different.
Usually, these offerings are a blatant attempt to rip off an unsuspecting purchaser. It takes a degree of assertiveness to go through return and refund procedures. Not every customer has that. Also, there is often a time limit after which no complaint will be upheld - even if it is valid.
