* Any replacement nut will require some final fettling to suit the host instrument.
Starting from an unshaped blank is the only way to be absolutely certain of achieving the fit needed by a given instrument. Unfortunately, as you appreciate, it involves a shedload of work. Tell yourself that you're worth it.
