Trading feedback: http://www.thefretboard.co.uk/discussion/72424/
In similar vein, the Oil City Pickups Diamond Geezer.
The Duncan tap is 50%. The OCP DG is more like 75%.
They certainly work well with overdrive/distortion pedals.
Tho, if you don’t care about the true single sound, get the Duncan Yngwie’s of DiMarzio injectors.
Works very well.
It sounds as though they don't sound how you want so maybe they're not right for you?
put a video on Instagram when I installed it if you’ll excuse the quality of both the playing and the video :
https://www.instagram.com/p/B3KQGRTHjf7/?igshid=f5uth91zkzoi
There are also other quality pickups built with steel poles and magnets on the base (similar to the SDS1) , from Harmonic Design, Fralin and probably others - not all pickups built that way sound as bad as those from a Fender Mexican Standard!
http://www.thefretboard.co.uk/discussion/89942/caspercaster#latest
I've just put one in mine. V.good in that it still sounds stratty without overpowering the other two pups . You lose a little bit of twang at the bottom which is to be expected.
