Music man-Tele mashup
KingSubKingSub Frets: 42
edited January 2020 in Making & Modding
Just started what should be an interesting project.
I've wanted to build a Tele style guitar for a while, but I also am a big fan of the compact MM Axis style body....so why not have a combo of the two!
I'm also planning on making my own neck for this project, but I'm going to use a donor neck from an OLP MM1 for starters, and then make my own later on.
The build has evolved as I'm going along, developing into a semi-hollow body (because freehand routing is fun!)
Hardware is going to be all black, with EMG T pickups.
Here's some pics on the build so far from block of wood to starting to shape the body.
  • Winny_PoohWinny_Pooh Frets: 8043
    Nice styling and a modern heel. Thumbs up
  • PeteCPeteC Frets: 459
    Excellent - how did you cut that teardrop f hole so precisely at the narrow end ?
    Great job - love MMs.  I have a lovely Silhouette Special which I parted with and regret.
  • KingSubKingSub Frets: 42
    how did you cut that teardrop f hole so precisely at the narrow end?
    Good old powered fret-saw/Hegner. Drilled the hole at the big end and then fed the blade though and reattached it.
    edited January 2020
    Finished off the body routing, quick shape and sand on the oscillating sander, and some edge routing.
    Wasn’t sure if I was going to curve the front edge or leave it crisp, but a slip of the router when cutting out the body decided it for me!
    Lots of fine sanding now.
  • TTonyTTony Frets: 28384
    That’s an interesting woods combination
    :+1:
    It's literally what I had lying around that was the right size!
    Back and middle stripe are beech, and the side-top pieces are sapele.
    Bit more sanding and shaping and a quick mock-up with hardware...
    0reaction image LOL 12reaction image Wow! 0reaction image Wisdom
  • JalapenoJalapeno Frets: 6451
    Looking stupendous ! love it !
    Feedback
  • I agree - really like the look of that.
    Having access to a laser cutter is useful!
    Just made a surround for the neck pickup.
    love it ! it reminds me a bit of some of the 80/90s Rickenbacker solids - the Atlantis was it ? ....or something like that.
    Nice clean look.
    I need to source black screws for the bridge and pickups (why sell a black bridge with silver screws?!).
    What's a good and not too expensive source?
    Or just go for the cheapest on eBay?
  • SargeSarge Frets: 2436
    Don't know why but it reminds me of a Shergold, lovely stuff.
  • SteveRobinsonSteveRobinson Frets: 7334
    Don't buy cheap screws, they can easily shear as you screw them in. A reputable supplier such as allparts or wd music is best.
    Cheers, will have a look at those.
    It's my first proper build from scratch, as opposed to kits, so still working out where is best for bits n pieces.
  • DanielsguitarsDanielsguitars Frets: 3354
    I really like the look of it, nice build
    www.danielsguitars.co.uk
    (formerly customkits)
  • lysanderlysander Frets: 574
    Excellent stuff ! I love these compact shapes too, looks great.
    What are are these pickups like, are they active ?
    I agree about avoiding cheap screws, removing a sheared screw is no fun, having had to do it for a once for a tuner, it’s not worth it.
    edited January 2020
    Yup active EMGs. They seem to get decent reviews, but we'll see.
    Couple more bits done this evening after work....
    Routed out an area for a recessed neck plate. Not as neat as I'd like, needs a bit of tidying up.
    Also drilled the hole for the jack socket.
    Been over the whole body with 600 paper, and debating whether to go up to 1200 before oiling/waxing.
    Oh yeah, and sanded off the headstock of the OLP neck. Some nice grain under there...
  • enteeentee Frets: 93
    Flipping heck, that looks excellent - nice original design.
    Vox 24, Variax 700, Epiphone Dot Studio (Cats Whiskers pups, custom inlay, custom pickguard), Gretsch 5238T (P90s/B3), Gibson Les Paul Zoot (rainbow), Gretsch 5135 PS, 'Graick' G2312TVR, BarileleBo (electric baritone ukulele G6199).
    Where will you be putting the battery ?
