Mods for the Boss DS-1?
I recently bought a faulty DS-1 off of ebay and have successfully repaired it.
There seems to be a plethora of mods on the web but are any of them actually worth while or is it best to keep t stock
  • ICBMICBM Frets: 72442
    Replace the LED with a bright orange one :).
  • phil_bphil_b Frets: 2010
    ok did that
    See! Sounds much better now :).
    I found a particularly nice yellow/gold one for my 40th Anniversary, which goes perfectly with the lettering.
    That's quite an aggressive tone you have dialed in ;).
  • mudslide73mudslide73 Frets: 3083
    The LED clipping (smoother) and diode lift (much louder and cleaner) mods are quite nice. The chip swap is good but very fiddly - I wrecked a perfectly good pedal trying the Allums version of this mod.
  • thermionicthermionic Frets: 9655
    Try removing C8.
  • I’ve got one that someone added a very bright blue LED too before me, I’ve never actually checked to see if they made any other mods though!
  • randellarandella Frets: 4184
    edited January 2020
    It baffles me that Boss still insist on using LEDs that you can't really see.
    its vintage?
    edited January 2020
    phil_b said:
    its vintage?
    So's Blackpool but you can still see it at night. :)
    well I have been using this pedal for a few weeks but one thing is really bugging me.
    when I turn the pedal off it still seems to have quite an affect on tone. ie the clean tone is very muddied to get back to my amps proper clean tone I have to remove the pedal completely and plug directly into the amp.
    anyone else had the same experience?
    That sounds like something is wrong/has been buggered about with in the bypass path.
    The bypass on a Boss pedal is buffered and doesn’t sound muddy, although it does drop the signal level a tiny bit - usually unnoticeable with only one in line.
