Pre-order now made for the custom edition. Looks like my trusty AMT SS-11a is going on the chopping block
https://origineffects.com/2020/01/16/press-release-revivaldrive-hot-rod/
The hotrod version is based on amp circuitry of JCM 800, Soldano, Mesa, Bogner, more of an 80's hard rock sound
My music:- https://soundcloud.com/hubobulous
I've been using it live for the last 3 years too.
At one gig, I was using it as the pre-amp into the return of a single channel valve amp and at the end of the gig a punter came up and complimented me on the sound and proceeded to take pics of the Marshall amp settings
Still going to try the Revival Drive Hotrod too though, nothing wrong with options.
I use a HXFX and it has two inputs for either expression pedal or amp control and I need one for an expression pedal, so I'm currently only able to switch channels and I do want the mid boost on both channels, and the Kossek FX MIDI pedal will allow me to change whatever I want in that regard.
