They're all good tbh. Not sure why I sold the Möbius a few years back - probably GAS. I sold the H9 as I didn’t want to use the app etc however you don’t really need to but it is just easier. Moved to the MD500 as I can run two fx at the same time option. All of course I chose because the common denominator was they have midi and I use a switcher to change presets
Hope it helps
I can only recommend the Mobius!
Mobius: vintage trem sounds like an actual amp's trem,
destroyer is the best sounding bit crusher i've played,
quadrature is way deeper than boss's option and the midi controllable pre/post routing is LUSH. The chorus/ flanger/vibrato are gorgeous the rest is good.
On the other hand the md500 is unbeatable for classic CE sounds and can be made to sound exactly like the boss/roland units it is emulating.
I'd go for the mobius but be aware it sounds like the signal is more heavily filtered on it which could make it sound darker to some ears.
I also have a mobius which I've used for the last 3 years or so. I could be persuaded to sell it as I'm sure I could get the md500 to cover it if I got off my backside!
I prefer the Wampler Terraform over those - really impressed. Bonus is smaller form factor and minimal fiddling to get nice sounds.
just do it
go on....
you know you want to
I find the amount of tap dancing and tap holding on the 2nd switch slightly annoying in a live setting - but don't want to go midi
PA Hire and Event Management
