Scratchy pots
fnptfnpt Frets: 746
The pots in my Laney Cub 12r are scratchy especially the drive and reverb ones with reverb being intermittent. Should I use wd40 or is it not advisable?
____
"You don't know what you've got till the whole thing's gone. The days are dark and the road is long."
  • gringopiggringopig Frets: 2648
    edited July 2020
  • fnptfnpt Frets: 746
    Thanks
    ____
  • ICBMICBM Frets: 72418
    Only use WD40 if proper contact cleaner has already been tried at least twice and failed - but then it is worth trying. At that point you have nothing to lose because the only remaining recourse is to replace the pots.
    I swear by the special WD40 contact cleaner.
    It's better than Servisol.
    I think the Electrolube EML is as well - I switched to it when RS stopped doing Servisol and it seems a bit better. They’re all good though.
    Thanks all - I'll look for servisol or electrolube.
    ____
    Is there any advantage in replacing the stock valves?
    I've not used the amp in a couple of years due to a faulty thermistor which I've finally decided to give it a go at replacing a week ago and also because I was quite happy with my Helix.
    However, having fixed the amp it took me 5m to realize that the sound of a valve amp is so much more satisfying than a digital emulator, regardless of how good it may be. So I'm upgrading it with a greenback celestion speaker and getting a couple of pedals.
    However, not having played the amp all this time I get the impression that I'm getting less drive from it than I used to and was wondering if it may be due to the valves (they are fully glowing when the amp is on).
    Also, is there a noticeable difference in sound by replacing fully working valves by other of supposedly better brand/ specs?
    ____
    edited January 2020
    If so it will be a preamp valve - first, just get one new one and replace them all in turn, and see if anything changes.
    Yes, but it's fairly marginal - and 'better' is very much a matter of personal preference/taste.
    I would get a standard cheap Shuguang 12AX7 first - you don't need to spend any more to find out if it's a valve problem, and in my opinion they're among the best-sounding of the modern valves anyway.
    https://www.karltone.co.uk/shuguang-12ax7b-ecc83-549-p.asp
    Thanks @ICBM I'll give it a go.
    ____
