I'm looking for some help to wire up a slightly different cabronita wiring scheme. The idea is to have just volume and tone controls with no selector switch. The neck pickup will be on by default, but pulling the cts push pull pot into the up position will bring in the bridge pickup in parallel.
As far as I understand it I just need to wire the neck pickup up to the volume and tone as if it were a single pickup guitar. However I’m unsure how to wire the bridge pickup to the push pull to bring it into the circuit.
can anyone help?
Simple To Service adds unnecessary unreliability by running the neck pickup through switching contacts when there's absolutely no need to.
I sketched it out that way to minimise signal leakage through the internal contacts of a cheap push-pull pot.
