12 string electric
13»
  • I bought my 340 new in 1989 for £650 - in 2020 money that's £1,627
  • tbmtbm Frets: 585
    edited February 2020
    Sooooo, I got one. A D'Angelico Premier DC 12-String. I should probably do a NGD post but I can't be arsed.
    Anyway, first impressions:
     - It's not light, but not mad heavy either
     - once you get the f*&ker in tune, it stays there! I've already rehearsed with it and it was rock solid.
     - it's easier to play then i imagined
     - the pups - Duncan designed and I assumes ceramic - are grand. Plenty of jangle and clarify.
     - it's pretty well put together, though some of the finishing is a little rough (marks on the binding, lining off the f holes) but nothing that would bother me. Might bother some else mind.
     - the colour is really nicely applied. Nothing cheap about it.
     - the Ovangkol fret-board is lovely and dark, and the inlays are neatly applied
     - I 100% did not need this guitar, but at €499 it seems great value. The gig bag is plenty sturdy too.
    Been jamming Hole Hearted. Need to find other cool 12 string songs to learn!
    Noise, randomness, ballistic uncertainty.
  • That looks great, congratulations.
  • KeefyKeefy Frets: 2325
    That looks lush! Nice contrast to the cat.
  • DominicDominic Frets: 16174
    viz said:
    I have an 18-string one which I haul out for Hotel C, Bon Jovi etc
    You Show -off you ;)
    Coda have a 12 string Taylor T5 secondhand .......I can actually see this being the perfect chassis for 12 strings somewhere between electric  and acoustic and able to do both .
    I would much prefer this to a Ricky.
  • chris45chris45 Frets: 221
    I found the T5 a funny beast.  It's a neat size and very well put together although I thought the neck felt a bit flimsy especially with the 12 strings on it - it felt if I were to donk the headstock slightly the neck would whiplash off.  I found the electric sound pretty good, but the acoustic sound only OK; probably fair for something trying to do two jobs.
  • Mike58Mike58 Frets: 162
    Burns Double six... good enough for Elvis!!
    I got my greenburst for £27 back in 1974, it's in bits now and I bet the Tri-Sonics are worth a few bob.
    The string spacing on them is great and I had a luthier ( Jimmy Moon) make me up an individual 12 string tunomatic bridge which did the trick re intonation but I never bothered with the 3rd octave string I just paired up the strings in unison ( less breakages).
  • I have exactly the same cat
  • tbmtbm Frets: 585
    Well Cheesy Bumps was created in the Fujigen plant so he’s clearly a better cat then yours.
  • Linus was hand wired in Mottingham SE London, he is the coolest cat in town.
  • tbmtbm Frets: 585
