Short scale Strat neck conversion
Hi all,
Could do with a bit of advice. I'm toying with the idea of having a 25" scale neck made for a Strat type guitar. I've got small hands and I want a neck that's similar to a PRS I have made. The current neck is a bit chunky for my smaller digits and the PRS neck seems perfect.
Excuse my ignorance but is it then a matter of just adjusting the intonation to suit i.e. the bridge can stay where it is etc? Do the saddles move backwards or forwards. Just want to be sure that I'm not going to run into problems around bridge position or running out of saddle adjustment etc.
Appreciate any insights.
Si
  • stickyfiddlestickyfiddle Frets: 27221
    Yep. As long as you get a "conversion neck" that should be made so the bridge is still in the right place, and you just need to check the intonation.
    I have one from USACG on my Cabronita Tele and it works very well.
  • paulnb57paulnb57 Frets: 3073
    If its a CONVERSION neck then it will all be fine.....the intonation might need fine tuning......make sure your maker is aware its a conversion neck.............anything else (e.g. a 25inch scale neck) would require the bridge relocating...
    Ive got a Squier Strat that is 24inch scale, they obviously used a conversion neck as it works on a 25.5inch Strat
  • Thanks all.
    In the spirit of edification what's the difference between a normal and conversion neck?
    Si
  • MtBMtB Frets: 922
    Watching this thread with interest. I've mover to a Jaguar as it's 24" scale, and find it more comfortable to play. Could you bolt a Jag neck onto a strat body?
    edited January 2020
    Thanks all.
    Si
    A "conversion neck" is one specifically made so that if fitted to a regular Strat or Tele with the normal neck pocket and bridge geometry it will have the frets in the right place for the distance between the neck pocket and the bridge.
    Any other neck (e.g a Jaguar, which is 24" scale) may have been built to some other dimensions that may have a different distance between neck pocket and bridge, so it's not guaranteed that it will work.
  • FunkfingersFunkfingers Frets: 14572
    ICBM once posted in another thread that Jaguar and Jazzmaster necks are interchangeable. The extra inch and a bit of scale length on the Jazzmaster neck is exactly the distance from the first fret to the nut.
    If you compared two twenty-one fret Stratocaster necks of 25.5" and 24.0" scale, respectively, the latter would require a fingerboard extension to accommodate the highest fret. (This might interfere with dropping in the pickguard and electronics assembly.)
  • SteveRobinsonSteveRobinson Frets: 7077
    Is 1/2" over the whole scale length going to make that much difference?
    Why not try a Strat neck with a slimmer profle first?
    edited January 2020
    That half inch is the difference between a Stratocaster and, say, a PRS CU/CE.
    I cannot think of a single occasion when I have changed between these two guitar types and thought, “eff me, this scale length is cramping my fretting hand.”
    Fender Strat to Jaguar or Mustang, I do notice but it takes very little time to acclimatise to the ride and get on with playing.
    It has been my experience that guitarists with markedly smaller hands have to find non-standard ways to finger some chord and riff shapes. This increases their chances of creating original sounding music.
  • @funkfingers - you may have bigger hands and longer fingers than I do.... it is pretty noticeable to me hence the reason I'm happy to throw some money are it!
  • CorvusCorvus Frets: 2942
    I like 25" for my own builds over Fender or Gibson scales, latter gets cramped up top and 25.5 feels too spaced sometimes. Definitely noticeable going from 25.5 to 25 for my mitts.
  • ICBMICBM Frets: 72619
    No I didn’t! Because they aren’t...
    The only directly interchangeable Fender necks are the 24”-scale Jaguar, Mustang, Duo-Sonic II etc, and the 22.5” - not 25.5” - Duo-Sonic, Musicmaster etc.
    As you say, the difference between the 24” and 25.5” scales is the fret at the *nut* end, so the distance from the neck pocket to the bridge is different and they are not compatible.
    For a Jazzmaster neck to fit on a Jaguar body it would actually need 23 frets - the 22 of the Jag plus the extra one at the nut. The neck pocket is much closer to the bridge on the Jag.
    I have small hands with a very poor reach and I really don’t notice the difference - I’ve used both a Strat and a Jaguar as my main gigging guitars and never been aware of having to adjust to them.
    I also play bass, so maybe I’m just used to moving my hand instead of stretching. I’m actually far more sensitive to the neck profile and the position relative to the body than I am to the scale length.
  • prowlaprowla Frets: 4942
    The distance from the nut to the 12th fret should be the same as from the 12th fret to the bridge.
