I've had one of these for about 10 years ... https://www.radialeng.com/product/pz-pre ....simple to use , flexible re sources and sounds wonderful...also virtually bombproof.
I also have a https://www.headwaymusicaudio.com/product/edb-2/ which is very similar in many respects but is way more fiddly to use IMHO.
I'm sure there are other examples out there..
Check out my YouTube channel for videos of luthier-built and vintage guitars!
Luthier Stories - My series of interviews with some of the world's greatest guitar makers
No matter how expensive and good quality your guitar is and the amount of processing you do to it
, if you listen to the results on crap speakers it will sound crap!
https://www.ebay.co.uk/itm/Boss-AD-8-Acoustic-Guitar-Processor-Pedal/352885696640
They're a very useful box for a non-purist - they have the usual tuner, EQ and anti-feedback, but also acoustic resonance simulation, onboard reverb (but thankfully no chorus, unlike most Boss acoustic preamps!) and a specific 'electric guitar amp' output as well as the usual balanced and unbalanced outputs. None of the sounds will win any prizes for accuracy no matter how good a pickup system you put through them, but that isn't why I have one - it's for all the situations where I might have to improvise and get a *usable* sound through whatever PA/amp etc is available.
... bearing in mind that no pickup system *ever* sounds as good as even quite a basic mic in front of the guitar.
https://www.thomann.de/gb/zoom_ac3_acoustic_guitar_fx.htm
I've got a BodyRez. It hasn't broken yet - although I too have had all kinds of problems with reliability with other TC products.
It definitely improves the sound of a piezo. At £50 second hand, it wasn't too much money down the drain if it broke.
Boss brought out the AD-2 a couple of months after I bought the TC. If I had known that was on the way, I would have waited and got that. That has the "Acoustic Resonance" as well, but not the bells and whistles of the bigger Boss. As well as Boss reliability, it's also an improvement on the TC as it has balanced out (by way of a TRS jack) - so you can have a balanced signal direct to a PA without a DI box.
