Mini-toggle pickup selector?
Am I right in thinking I could use a mini-toggle as a 3-way pickup selector?
If so, what type would I need - my assumption is a DPDT on-on-on (like this), but could do with some forum lore on this please.
Merci!
  • ICBMICBM Frets: 72646
    Yes, that’s correct. Simply connect both middle terminals to the output, and both terminals at each end to the inputs - that’s more reliable than only using one.
  • Whoop, thanks @ICBM, that sorts out the backup plan for my PRS then!
    As stupid as it seems, I’m trying to preserve the sweet-switch “look” without having to lose out on certain sounds. I’ve got an actual sweet switch and 5-way rotary in there atm, but can’t really say I’m too fussed about the sweet switch so far. I’m pretty much a bridge-pickup only player these days anyway, so should be able to cope with the fiddlier toggle too without much impact. :)
    That’s not a stupid thing to do - early PRSs are relatively valuable, and enlarging the Sweet Switch hole is irreversible.
  • Ah well that's the stupid part - someone had already enlarged the hole before I bought it! Besides, there's enough changes and wear & tear to remove most of the collector value of this one - it's absolutely a player's grade guitar, and all the better for it!
    A friend of mine has a 3d printer so I'm having a couple of deep-fit washers made up to better situate the mini-toggle into the enlarged hole as a temporary measure until I decide what to do in the long-run (i.e. maple plug & refin or similar).
  • FunkfingersFunkfingers Frets: 14573
    Which three sounds do you use the most?
    If the switch hole has already been enlarged to pot shaft proportions, it should accept a 4P3T on/on/on switch. This could be configured to offer the John Petrucci circuit. Neck / Inside Coils / Bridge.
  • Good shout, I didn't realise his sig's had those. The only trouble is that I'm particularly keen to keep things limited to a mini-toggle if possible.
    If I had the choice, I'd have a 5-way rotary/blade with the following options:
    • Bridge HB
    • Inner-coils in parallel
    • Neck HB
    • Inner-coils in series
    • Neck SC
    I could happily live with the first three though.
