Has anyone got an allergy to metals used in Acoustic strings?
I haven't been to the doctors yet, so bare with me, but I seem to be developing an allergy and it when I'm playing guitar that's causing problems. I'm only playing acoustic at the moment, picking an electric up maybe once every few weeks.
I think its Zinc content. I put some 80/20 (so %20 Zinc content - I checked with the manufacture), I'm sneezing and have saw eyes within 5 mins, my fingers feel like they're burning in a mild acid after half hour or so. Back to PB strings and I still sneeze a little, but my fingers are fine even after a few hours. Admittedly it doesn't help that I have a stinker of a cold at the moment, but I've noticed the sneezing and saw eyes for the last few months now.
Seems the Newtone PB strings still have Zinc in them according to Neil Silverman at Newtone, though only a small amount.
There must be a manufacture that doesn't use Zinc. I'll do anything I can to not use Elixirs, but fear that may be my only choice as they're covered in bloody plastic. I've never got on with Monels/Nickle acoustic strings personally...
I've heard of Nickle allergies and people using Stainless strings, but Electric strings don't seem to cause me issues. I know if I have a cheep belt buckle it can cause me irritations to the skin, so I don't think I'm going mad.
Interested to hear if anyone else has a problem.
I'm also going to have to consider different strings I think. I've already taken the cover off the bass, which seems to have helped, but I still had a bit of a reaction after band last night.
If you don't like Elixirs - I can't stand them either - try DR Dragon Skin, they're the only coated strings I've tried that I can get on with. They feel odd at first but it wears off.
I know of several instances where using clear nail varnish as a barrier between skin & nickel containing material (spectacle frames, watches) worked well as a barrier.
Is spraying the offending guitar parts with clear laquer an option?
I'm definitely not promoting nitro over polyester here for better tone
Think I may as well get some plastic coated Elixirs if that's the case
Bit hard to tell, but I'm assuming it's the wounds. The 80/20 hammered me compared to most PB.
Admittedly there a lot of assumption on my part, I realise I need to go and get it checked out ultimately - Just trying to work it out a little better in the mean time. Christ, I couldn't get an appointment for at least two weeks at my GP.
no, semi seriously, could try experiment with latex gloves of various thickness
actually not latex, lots of people are allergic - nitrile?
Have you considered string treatments like GHS Fast Fret, or maybe a little pure solid beeswax or violin rosin?
Just thinking that it could possibly reduce the string contact a little without detriment to the tone (maybe...).
Edit : https://nickelallergyguitar.wordpress.com/
https://www.stringsdirect.co.uk/blog/working-around-a-nickel-allergy/
https://www.acousticguitarforum.com/forums/showthread.php?t=432890
well just stuck some DR Dragon Skins on, I’m amazed. Yes they feel a little odd, especially the coated plains, but this is the first time I’ve put coated strings on anything and I haven’t wanted to cut the bloody things off immediately!! They sound pretty damn good already - after only 15 mins of playing. I know Elixirs settle down after a few days, but then they just sound like strings covered in plastic to me.
