A job for today, and some tool porn :)
Because I am not very organised, I tend to pick up the next tool rather than sharpening the one I have been using. Speeds up work at the time, but leaves me with something of a job to do every so often, and that job is for today. Primary bevels on watergrinder (at around 25 deg) with secondary on jap waterstone to 6000 grit  and final strop. They are mostly A2 steel, and dont take *quite* such a fine edge as more traditional steels. But, yes, work cut out. Oh, and going to sharpen my kitchen knives too.......
some old 5001 chisels, various planes
https://imgur.com/lBc9NHE.jpg
do I really need 3 size 6 planes?
https://imgur.com/1hcug2Q.jpg
some chisels that were my engagement gift (well, my wife got a ring!)
https://imgur.com/AypL8Ai.jpg
Better get a move on.......
Adam
  • MusicwolfMusicwolf Frets: 3661
    By a strange coincidence I've been sharpening my tools this week
  • KalimnaKalimna Frets: 1540
    Stone axes?
    Yes.  There’s no doubt that metal tools have progressed a long way but I still prefer the authentic ‘axe in the room’ feel that only comes from stone implements.
    And perfect for creating bass guitars.
    Adam
  • normula1normula1 Frets: 640
    Yes you do need 3 size 6 planes. You can be 3 times as productive....ahem ;)
    edited February 2020
    Thats what i reckon too Anyway, heres the result. Lots of sharpness, several bald spots on my arms and no lacerations (a first).
    https://i.imgur.com/V530iev.jpg
    And i didnt even start on the knives
  • RabsRabs Frets: 2610
    Theres more than one type of chisel?    :D
    Yep. Blunt ones and sharp ones :)
  • mrkbmrkb Frets: 6884
    And ones you’ve whacked with a hammer, and those you haven’t (yet)
    Karma......
    Ebay mark7777_1
  • BigMonkaBigMonka Frets: 1779
    Ooh that's a lovely selection of tools! Those No.6s are expensive too, I've had to settle for just a No.4 at the moment which isn't ideal for trying to learn to flatten something.
    Cheers - a collection built up from family pass-downs, engagement gift and folk selling stuff on woodworking forums. Those 6's are a delight to use, and the Clifton irons sharpen much more easily than the A2 blades. The top right is a 5 1/2 from Lie Nielsen back when you could specify cocobolo handles :)
    I'd recommend a 5 1/2 to anyone - easily suitable for flattening, and more heft than a 4 (which is too small for my hands to hold comfortably).
    Anyway - I finished up the knives last night, and here they are....
    https://i.imgur.com/poyqBLB.jpg
    Somehow, I still managed not to slice my hand whilst doing this - maybe they are still blunt?
    Adam
  • TTonyTTony Frets: 27621
    Sharpening is an art I have yet to master.
    So I have both tool envy and skill envy!!
    Nice knife selection too, do your chef skills match your woodworking/sharpening skills?!
    I do a mean chile, and not too shabby at bread :)
  • ESBlondeESBlonde Frets: 3592
    It's one of those things that I keep coming back to. There are so many experts in yootoob land with different systems, methods and ideas. I've faffed about with all of them I think.
    I've settled on the idea that getting the primary bevel right, square and even is the hard time consuming bit.
    Putting on a secondary bevel and honing it is easy and takes a lot less effort than I imagined. Once you've got that edge it's very easy to just re-hone it as needed, sometimes just a strop with some compound and a few strokes and you're off cutting again.
    Old time craftsmen would be astonished at all this 9000 grit diamond plate stuff, they just got an edge and carried on. Sometimes I feel I obsess about it all to much.
    Indeed. I used to religiously polish through the grits 800-1000-3000-6000-10000 on the secondary bevel. Thats after, as you rightly point out, the hard part of generating a square primary on a powered waterstone. Good grief, A2 steel on waterstones can take a while :)
    Now, i go from primary (coarse) to secondary (1000 then 6000 or 10000 depending on use) then strop.
    Much finer secondary bevel means quicker repeat hones/strops.
    If possible, i reckon the best way to learn is to have someone show you rather than copy methods from youtube or books.
    The thing about the older craftsmen though, they were doing this day in day out with oilstones because there wasnt really an alternative. So as an apprenticr their muscle memory was developed, with their master showing how to improve. As hobbyists, its much harder to do this. Add to that some modern steels, and diamond plates, for instance, become necessary for speed.
    I think you make sense here, as a hobbiest i sometimes can go weeks without sharpening. Mainly because I haven't used the tool (or any tool) for a period. This makes muscle memory a non starter in the main. I will get to a point where I start sharpening, and then creap into the workshop for an hour several days/evenings on the trott just to fine hone a bunch of stuff, this gives me quite satisfaction. Everything then gets put away ready to use when I get a round tuit!
