I've always thought they seemed good because without them the nut has to be filed so precisely to get good action and intonation and I found that difficult to do myself and have had bad experiences of paying for it to be done only to get the instrument back without it being done. So I thought how much easier it would be if the nut could be filed all the way down cause the string would actually be sitting on the zero fret.
I've had 3 Status, 3 Sandbergs, and 1 Marleaux with zero frets.
The Marleaux I had the longest - a good 10 years. Only 1 of them ever needed any zero fret work - and that was a brand new Sandberg where it was a bit high and needed filing down a bit.
Some bass makers have tight nuts / string guides and a regular fret. Some put little grooves in the zero fret and a looser guide. Some use a harder material for the zero fret.
I played the Marleaux a huge amount with plenty of open notes and a load of stuff in B flat, E flat where the 1st fret would be fretted putting pressure on the 1st fret and the zero fret. For 10 years. Still didn't need any work. The bass had Prosteels on it too. Not nickels or flats.
