I'd look at adding a pedal to improve the sound first. I've got a TC Electronic Body Rez, but I bought that before the Boss AD-2 was released. These days I'd buy the Boss given my previous experience of TC (lack of) reliability. At £50 second hand though, it's not the end of the world if the TC does die.
Both those pedals will use digital trickery to improve the sound. I know from experience that the Body Rez does noticeably improve the sound of an undersaddle piezo.
There are IRs for acoustics online. Would be worth downloading some and trying with the Helix.
Yeah but no but ...
1) Transducer strip thickness differences would make it necessary to modify or replace the original Faith bridge.
2) Unless the control modules are of identical size and shape, it would be necessary to modify the side of the guitar body.
It ought to be possible to make your Faith sound more like the Rory by use of EQ and, possibly, compression.
I was blathering about using the multiband compressor in Helix/Stomp to sweeten an acoustic pickup sound - can help tame the spikiness of the top end without compressing the low end into feedback hell.
Although if the internal system is piezo-UST-based and can be set to a flat response, then something like a Fishman Aura preamp, which is designed specifically to take a UST signal, will work well. The simple TC/Boss-type 'resonance' pedals would go a fair way to it too.
The Fishman Sonicore is a piezo system.
The Helix is the quickest route. 3sigma audio have IR's specifically for piezo systems so you have something similar to the Aura preamp already, you just need the $10 IR.
Open mic nights might need a different approach, where you just hand somebody your lead, in which case a better all in one system may work better.
Also, IR's can need feedback treatment as they bring many of the issues of microphones, in which case a magnetic system may offer better feedback rejection.
If only for the fact he didn't want external pedals etc and wanted to maintain the onboard tuner I'd have done exactly the same, stuck a decent internal pickup in and lent him my AD10 preamp pedal, as said above though that can lead to issues with open mic nights.
https://www.faithguitars.com/guitars/by-series/naked-series/product/125-fkv-naked-venus-cut-electro
https://www.faithguitars.com/guitars/by-series/naked-series/product/238-fkvcd-naked-venus-cut-electro-cedar-mahogany
Perhaps, the "improvements" you desire can be achieved by merely upgrading the onboard pre-amp/controls module?
This.
I wired the undersaddle piezo directly to the jack and use a Zoom AC-3 pedal.
I spent years faffing with the onboard preamp during gigs to try and find the sweet spot, now I just plug and play, with no batteries to worry about and the best live acoustic sound I've ever had by some margin.
I almost can't wait for the Fishman preamp in my Gibson to die, in fact I probably won't wait and will bin it anyway.
I'm sick of unnatural, unpredictable tones full of spikes and notches, the latest outboard pedals are fantastic and you can use them for all your guitars.
And when a new latest outboard box comes out, you simply replace it. Why have a nice acoustic guitar that will get better with age, and lumber it with an internal electronics package that will be obsolete well before that - if it doesn’t fail first...
The modern generation of outboard preamps can sound great with any type of pickup in the guitar, including the dreaded traditional piezo UST, so why bother making the guitar more complicated and unreliable than it needs to be?
I've always suspected that the tone-enhancing properties of a hole in the side of the guitar were discovered exactly like that...
It actually vastly improved the sound for the player, it was a bit of a plinky old thing before ditching the preamp.
https://www.thefretboard.co.uk/discussion/175640/ditching-your-onboard-preamp?new=1
