Help! Reaper suddenly outputs no sound
Hey folks
I've been using Reaper for many months, and suddenly, there's no sound. Levels on the tracks are going up and down as you'd expect, but nothing coming out of the speakers. It was working this morning, I left it running, but went back to it this afternoon and nothing.
Is there something obvious I've pressed? Other applications are playing music fine, so it's specifically Reaper. I'm using a Focusrite 6i6 in case that helps.
I had the Focusrite Control app open at one point, so wonder if it's anything to do with that?
Cheers!
________________________________________________
Telecaster American Deluxe, Cornell Romany amp, without the talent to use them properly
  • Check the sound device. It may have picked up something else that's plugged in.
  • ijontyijonty Frets: 32
    Do you mean the Focusrite? Or in the system preferences in the Mac? I've tried that latter.
  • JAYJOJAYJO Frets: 1533
    edited March 2020
    Can you close Reaper and open it again.
    Neither. I mean in Reaper. Top right hand corner is the quickest way there.
    Yeah, I did that, and turned the entire mac off to start again. Will try what @Legionreturns suggests...
    Thanks all, think it was a problem with the Focusrite, as I restarted that and it's ok now.
  • andy_kandy_k Frets: 821
    focusrite sometimes resets things if you switch apps, My 48k Reaper sessions became 44k sessions when I used logic, or it might have been Audacity that did it--had to change settings on the interface, focusrite scarlet.
