SUHR ACE
VoxsupertwinVoxsupertwin Frets: 338
edited March 2020 in Amps
Anyone know if you can use the SUHR ACE without an amp?.....looking to record from its output using a line level signal straight in but no amp or speaker cab involved.....just want to get the speaker emulation applied to my signal.....
  • SunDevilSunDevil Frets: 511
    Nope - it's just a speaker emulator but not a load
    You need the Reactive Load with the ACE or Reactive load IR to avoid a firework display from your amp
  • I don’t want to,use an amp at all.....just take the output of my pedalboard into the ACE and then into my Focusrite DAW interface......
    @SunDevil is telling you that the Suhr ACE is merely a speaker emulating DI...not a load box.
    Your amp needs to see a load...usually a speaker. But if you want silent recording, you'd need a 'load box' to replace the speaker...such as the Suhr RL...or you can get a single device to do both jobs, e.g. the Suhr RL IR
  • Re-read...
    No amp...*at all*...erm, okay...you can use the ACE...but it wants a line level input signal (typical pedalboard signal might be a bit low) and ideally your pedalboard would have some form of 'amp-like' pedal on it.
  • They are on a good deal at Guitar Guitar....£145.....£170 discount....I’ll get one and if it’s not right it can always go back......thanks to all.....
  • Stonking price! I use mine at gigs instead of mic'ing up...sounds great.
    Arrived today....it was £149.....still an amazing price.....it does work without an amp or a speaker using the line in and out sockets, but you do have to have your level up around 0db for the tone controls to function properly.....
    I tried it with one of my amps....and it is very good.....using a dummy load....performance is much better and more what I expected...so I will use it with the amp for recording....no hum or extraneous noise on the signal either....records really well into Logic.
  • Yeah, I gave mine a go...just feeding my pedalboard into the line input...needed a lot of boosting.
    Glad it's going to be useful for you ;)
