Tuning a short scale guitar to A
paulnb57paulnb57 Frets: 3075
edited April 2020 in Guitar
Ive got a Squier Mini Strat (22.75 inch) scale Im faffing with and am considering tuning to A, can I use 10’s or will they go ping! and all end in tears.....
Thoughts...
  • crunchmancrunchman Frets: 11472
    I suspect A will be too high.  I've got a little Breedlove travel acoustic that I've just measured the scale on at 19.5" or thereabouts.  That originally came tuned to A, but I've dropped it to G# as the strings seemed a bit tight.
  • paulnb57paulnb57 Frets: 3075
    Do you use usual gauge strings, 9’s/10’s?
  • ICBMICBM Frets: 72680
    22.75" is the same scale length as to the second fret on a standard scale, so you will get the same tension with your usual string gauge if you tune up to F#. A is probably too high unless you go to lighter strings - the octave G (three semitones above the top string) on a 12-string is normally an 8 or 9, so for three semitones above the F# I would try 8s or 9s.
    It's acoustic strings, but they are my usual gauge (11s).
  • DLMDLM Frets: 2513
    There have been a fair few threads and posts about this, here's links to a couple:
    When I get around to sorting out my miKro, I'll try to gather everything together in one place. I'm going to get it new machine heads and try the Ernie Ball Not Even Slinky set I bought for it in standard tuning. I'd not normally touch EBs with a bargepole after long-standing reliability issues, but this was the cheapest option to get a full set at close to the gauges I calculated for standard using stringtensionpro.com: 12, 16, plain 24 (!), 32, 44, 56. I also have a few sets of eights around to try tuning it to higher pitches along the lines ICBM posted about above.
