The best are the ones that Fender sell for the job with 2 long sides.
This is what you need:
https://www.homeoftone.co.uk/products/genuine-fender-1-8-hex-allen-truss-rod-adjustment-wrench
These are the best not only because they're the right size but because the short end is longer than normal, so they're easily identifiable as well as more easily reaching the adjuster nut and the neck tilt (which is the same size).
