WTB: Telecaster neck (CV, standard squier, unbranded etc)
Before I go to the fleabay, thought I might check here first. Would like to go a bit higher quality that a bullet neck, so maybe a CV, or something. Unbranded etc...
    edited April 2020
    @Creed_Clicks ;;
    OK lets try again, Ive had a scratch around and have there two jokers
    I have too many guitars already and these wont get used
    The top one was an ebay purchase years ago, it was used on an early project and is fine, but its been in storage for ages, it has an issue, the top e tuner hole was drilled 1mm oversize at the factory, 11mm instead of 10....wrap some masking tape round the body of the tuner where it goes through the hole and its fine, med jumbo ish, a bit of flame, heel truss rod adjustment, no nut, quite a thick poly finish, small cracks in the finish at tje tuner screw holes, not too bad a budget neck....
    30quid mailed
    Bottom one is by GSP Basses, is finished in thin Nitro, med jumbo, two way truss rod, Locking, staggered tuners
    100quid mailed...
    edited April 2020
  • Creed_ClicksCreed_Clicks Frets: 1388
    @paulnb57 no pics, I see you edited the post from the one earlier?
    edited April 2020
    @Creed_Clicks ;Yep Im a retard...Im on it!
  • skinfreakskinfreak Frets: 200
    Justin case there is this one on fleabay; https://www.ebay.co.uk/itm/233544819296
  • lysanderlysander Frets: 574
    @paulnb57 would you mind measuring the nut width and thickness of the GSO neck ?
    Would be interested if it’s the wide / thin type
    edited April 2020
    @lysander  neck width is just shy of 1.7 inches wide at the nut and about .980inch deep at first, twelfth and onward! Not wide n thin!
    Ok thanks for checking @paulnb57 !
