Where to start with Reaper
With the Coronavirus lock down preventing me getting out I’m turning to recording. Nothing complicated. I need to record some guitar parts for a solo singer, so that she can practice at home. I also want to record rhythm and solo guitar for an mp3 that I’ve been sent, then send the tracks back for mix down. Neither of these are complicated, and the latter doesn’t need any post recording treatment.
So far I’ve loaded Reaper onto an SSD Windows laptop, and begun to read the manual. Obviously I could spend a couple of days watching YouTube videos, but I thought I’d start by delving into the forum’s knowledge bank. Where would you go from here?
  • stratman3142stratman3142 Frets: 2197
    The Kenny Gioia videos on the Reaper website.
    It's not a competition.
  • JAYJOJAYJO Frets: 1527
    You can download a portable version of Reaper you can take with you on a usb stick. May be handy . You will be limited with the plugins you can use.
  • PolarityManPolarityMan Frets: 7287
    Have you used a DAW before?
    ဈǝᴉʇsɐoʇǝsǝǝɥɔဪቌ
  • JalapenoJalapeno Frets: 6390
    Which interface ?
    Feedback
  • Danny1969Danny1969 Frets: 10407
    Assuming you have an interface with the drivers installed
    Click Options then preferences then Audio then devices ... make sure your interface is selected for in \ out and not the Windows Wave out or similar
    Click track - insert new track - click the input of the track and select the input so it matchs what your guitars plugged in to on your audio interface ... in 1 for example
    Then hit CTRL & R to begin recording
  • smigeonsmigeon Frets: 283
    I found this to be a very informative video when I (just recently) got started with Reaper:
    It's slightly slow going at the start, but when it gets going it takes you quite a way along. I found watching it to be a very good use of my time.
  • MoominpapaMoominpapa Frets: 1649
    Kenny Gioia is the man.
  • RolandRoland Frets: 8706
    Jalapeno said:
    Which interface ?
    Danny1969 said:
    Assuming you have an interface with the drivers installed ...
      It's only a single guitar input, so I was hoping to go via USB from my AxeFX. Reaper's showing a 10/10ms latency. However what I'm hearing is more than 100ms, which is presumably coming from the AxeFX USB. My laptop doesn't have an audio input, only USB, so I need to pause for thought.
    What laptop is it? Many laptops have a single port which users assume is only a headphone port but it’s actually dynamically switchable in software to operate as a mic  in a line in or head phone out. Not all laptops have this feature but quite common on Dell \ HP \ Macbook Pro etc
    Or monitor through the Helix and turn off input monitoring on the channel your recording on. Be no latency at all then
    This
    Feedback
  • I had this when connecting my helix to a windows laptop via usb and monitoring everything via the helix.
    It ended up that my usb output sample rate was different to the one in reaper , when I swapped them both to be 48khz, latency disappeared.
    Thanks, that’s useful.
    When you "arm" recording on a track in Reaper it will show the level meters. Your basic input should be between -18 to -6. Use the trim pot on your interface so peaks at -6 max.
    It's easier to make a quiet track louder afterwards and impossible to reduce an original that's clipped to sh1te.
